noob here - I recently put Lubuntu on a lenovo 100e gen 2 chromebook and the only issue is that it cannot identify the soundcard. Does anyone know what might be a solution?
I've tried reinstalling alsa tools and pulse audio, and rebooting of course, but that isn't the issue. If I run alsamixer the readout is:
ALSA lib conf.c:5178:(_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory
ALSA lib confmisc.c:422:(snd_func_concat) error evaluating strings
ALSA lib conf.c:5178:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1334:(snd_func_refer) error evaluating name
ALSA lib conf.c:5178:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5701:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib control.c:1528:(snd_ctl_open_noupdate) Invalid CTL default
cannot open mixer: No such file or directory
this is a current Lubuntu 22.04.3 LTS/Jammy Jelly distro. Obviously there's something about a library not existing, but I've re-installed alsa multiple times and that just isn't fixing it.
EDIT: I did try the code from the suggested link, that did not work. I.e., running:
git clone https://github.com/WeirdTreeThing/chromebook-linux-audio.git
cd audio-scripts
./setup-audio
resulted in no sound, and the following output:
Cloning into 'chromebook-linux-audio'...
remote: Enumerating objects: 287, done.
remote: Counting objects: 100% (67/67), done.
remote: Compressing objects: 100% (47/47), done.
remote: Total 287 (delta 34), reused 46 (delta 20), pack-reused 220
Receiving objects: 100% (287/287), 289.43 KiB | 2.28 MiB/s, done.
Resolving deltas: 100% (154/154), done.
bash: cd: audio-scripts: No such file or directory
bash: ./setup-audio: No such file or directory
Additionally, running
sudo lshw -C sound
appears to identify the "soundcard"/multimedia piece, but I don't truly know what some of the output means. That outputs:
  *-multimedia
       description: Multimedia audio controller
       product: Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
       vendor: Intel Corporation
       physical id: e
       bus info: pci@0000:00:0e.0
       version: 0b
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=snd_soc_skl latency=0
       resources: irq:25 memory:91210000-91213fff memory:91000000-910fffff
Update: After pointing to the updated directory, the following was output, but with no change and no recognition of output devices by PulseAudio:
Using sof
Installing SOF
Installing SOF firmware
Installing modprobe config
Installing UCM configuration
Cloning into '/tmp/chromebook-ucm-conf'...
remote: Enumerating objects: 864, done.
remote: Counting objects: 100% (385/385), done.
remote: Compressing objects: 100% (239/239), done.
remote: Total 864 (delta 187), reused 305 (delta 122), pack-reused 479
Receiving objects: 100% (864/864), 158.26 KiB | 1.32 MiB/s, done.
Resolving deltas: 100% (413/413), done.
Updating libasound2 (this may take some time)
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Audio installed successfully! Reboot to finish setup.
I'm not sure at this point what is wrong - everything says it should work. I attempted both SOF and AVS versions of drivers, with both saying they successfully worked and neither accomplishing anything - but as AVS is unstable it did cause problems with GRUB and PulseAudio for my setup.
Am I missing something basic? I did try to restart PulseAudio and that did not help. Running alsamixer also shows the same output as before.
The name if the audio script directory chanced.
cd chromebook-linux-audio
./setup-audio
Then reboot.
