Possible Duplicate:
How do I fix Flash issues?
I'm having this issue trying to uninstall and/or upgrade the Adobe flash player plug-in. Here's what I've ran through the terminal:
$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
linux-headers-3.0.0-13-generic libgladeui-1-11
linux-headers-3.0.0-19-generic linux-headers-3.0.0-13 linux-headers-3.0.0-19
erlang-base
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
adobe-flashplugin
0 upgraded, 0 newly installed, 1 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 10.2 MB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 375840 files and directories currently installed.)
Removing adobe-flashplugin ...
update-alternatives: error: no alternatives for iceape-flashplugin.
dpkg: error processing adobe-flashplugin (--remove):
subprocess installed pre-removal script returned error exit status 2
No apport report written because MaxReports is reached already
postinst called with argument `abort-remove'
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 1
adobe-flashplugin
Please advise if you can. Let me know if there is any other info you need.
