I'm trying to install swool using perl on ubuntu server then i get bellow error:
ERROR: `phpize' failed
As i searched turns out i should install php-dev but then i got below errors:
 php8.2-dev : Depends: autoconf (>= 2.63) but it is not installable
              Depends: automake (>= 1.11) but it is not installable
              Depends: shtool but it is not installable
              Depends: libtool (>= 2.4.6-0.1~) but it is not installable
              Recommends: pkg-php-tools but it is not installable
I can't find any solutions on https://stackoverflow.com or https://askubuntu.com , it would be great If you can help me
kosar
PHP 8.2 is not in the default Ubuntu 20.04 repos, so you will have to use ppa:ondrej/php. You didn't mention if you are using it.
This is what I just tested and it works on my Ubuntu 20.04 machine:
sudo add-apt-repository ppa:ondrej/php
sudo apt update
sudo apt upgrade
sudo apt install php8.2-dev
sotirov
  • 4,379
