apt install php8.2-curl
Reading package lists... Done
Building dependency tree
E: Unable to locate package php8.2-curl
E: Couldn't find any package by glob 'php8.2-curl'
E: Couldn't find any package by regex 'php8.2-curl'
Then tried:
apt install php-curl
php-curl : Depends: php7.2-curl but it is not going to be installed
Any Thoughts?
