Grub2 - Community Ubuntu Documentation says the following:
Saving an OS can be achieved by running sudo grub-set-default if DEFAULT=saved is set in /etc/default/grub. It may also be saved if GRUB_SAVEDEFAULT=true is also set in /etc/default/grub. In this case, the default OS remains until a new OS is manually selected from the GRUB 2 menu or the grub-set-default command is executed.
I put the lines DEFAULT=saved AND GRUB_SAVEDEFAULT=true in /etc/default/grub, and ran sudo grub-set-default.  Here is the output:
$ sudo grub-set-default
entry not specified.
Usage: grub-set-default [OPTION] entry
Set the default boot entry for GRUB.
  -h, --help              print this message and exit
  -v, --version           print the version information and exit
  --boot-directory=DIR    expect GRUB images under the directory DIR/grub
                          instead of the /boot/grub directory
ENTRY is a number or a menu item title.
Report bugs to <bug-grub@gnu.org>.
Am I not following the documentation correctly? What's the correct way to do this?
