I am having Windows and Ubuntu installed side by side. So every time when I boot (when the GRUB menu appears) I have to press down key to select a specific OS.
I want to edit the code of GRUB so that it remembers what I boot last. Like if I boot Ubuntu last time, then by default selected option will be Ubuntu in menu, similarly for windows.
Lucio
  • 19,191
  • 32
  • 112
  • 191
Kuldeep
  • 97
You need to set save_default in /etc/default/grub (at the top of the file is OK):
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
After adding these two lines to /etc/default/grub, you then need to update Grub's configuration using this command:
sudo update-grub
This should add the line savedefault at the end of each entry in /boot/grub/grub.cfg.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Marty Fried
  • 18,944
