Short version: After trying (and failing) to install the AMD radeon proprietary drivers, I uninstalled them and removed the packages it installed, but now:
- At boot, my graphics card is
UNCLAIMED. - GDM wont start until I do:
sudo modprobe amdgpu(which also claims my graphics card) - After login,
DISPLAYis now:1instead of:0which I don't understand
What should I do to return to a working system that actually boots?
Details
Everything was working fine on my newly installed was working fine, except x11vnc.
To fix that I tried to install the (utter mess that is the) proprietary AMD radeon drivers using amdgpu-install_22.20.50200-1_all.deb, and it failed miserably. After modifying /etc/apt/sources.list.d/* multiple times, it finally ended up failing to build the kernel module because of a gcc version mismatch, which is when I gave up. To clean up the botched installation attempt, I ran:
sudo amdgpu-install --uninstall
sudo apt purge amdgpu-install
sudo apt autoremove
After a reboot, gdm no longer starts. I noticed that sudo lshw -c display showed:
$ sudo lshw -c display
*-display UNCLAIMED
description: VGA compatible controller
product: Baffin [Radeon RX 550 640SP / RX 560/560X]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:02:00.0
version: ff
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list
configuration: latency=0
resources: memory:d0000000-dfffffff memory:cfe00000-cfffffff ioport:b000(size=256) memory:fbb80000-fbbbffff memory:c0000-dffff
*-graphics
product: VESA VGA
physical id: 1
logical name: /dev/fb0
capabilities: fb
configuration: depth=32 resolution=1280,1024
So I compared /var/log/Xorg.0.log (which is now failing) with ~/.local/share/xorg/Xorg.0.log (which has not been rewritten since last time it succeeded booting) and noticed that the latter had a LoadModule: "amdgpu" line, so I tried sudo modprobe amdgpu, gdm started and now the graphics card is also "claimed":
*-display
physical id: 0
version: ff
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=amdgpu latency=0
resources: irq:32 memory:d0000000-dfffffff memory:cfe00000-cfffffff ioport:b000(size=256) memory:fbb80000-fbbbffff memory:c0000-dffff
Once I log in, I how have DISPLAY=:1 where before the driver installation attempt it was DISPLAY=:0. This could be a side effect of first :0 trying to start which fails on the unrecognized card, and then after the modprobe it appears as if there now is a new (recognized) graphics card, and so it is given :1.
What can I do to clean up this mess? I don't want to hardcode loading of amdgpu, because I don't think it was hardcoded before...
I don't think it would be too much work to reinstall Ubuntu 22.04 from scratch, but needlessly to say, it would prefer to understand what went wrong and fix it, if possible.
Do you know what I should do to get amdgpu to load automatically and get DISPLAY :0 to work again?
