I have just installed ubuntu 20.04 (alone, no dual boot) on a hp elitebook laptop (which is new). Wifi worked for a few hours, but then stopped working ("No wifi adapter found"). Ethernet is working fine though.
I have tried several options to resolve it (especially this and this), but none of them worked. Secure boot and fast boot options are disabled.
Output of sudo lshw -C network
*-network
description: Ethernet interface
produit: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
fabricant: Realtek Semiconductor Co., Ltd.
identifiant matériel: 0
information bus: pci@0000:01:00.0
nom logique: enp1s0
version: 15
numéro de série: bc:0f:f3:72:ec:bd
taille: 100Mbit/s
capacité: 1Gbit/s
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration : autonegotiation=on broadcast=yes driver=r8169 driverversion=6.2.0-32-generic duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=140.77.152.15 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
ressources : irq:56 portE/S:2000(taille=256) mémoire:fb704000-fb704fff mémoire:fb700000-fb703fff
*-network NON-RÉCLAMÉ
description: Network controller
produit: MEDIATEK Corp.
fabricant: MEDIATEK Corp.
information bus: pci@0000:02:00.0
version: 00
bits: 64 bits
horloge: 33MHz
fonctionnalités: pciexpress msi pm cap_list
configuration : latency=0
ressources : mémoire:fb500000-fb5fffff mémoire:fb600000-fb607fff
Output of lspci -nn
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex [1022:1630]
00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU [1022:1631]
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge [1022:1634]
00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge [1022:1634]
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
00:02.4 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge [1022:1634]
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus [1022:1635]
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 51)
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0 [1022:166a]
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1 [1022:166b]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2 [1022:166c]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3 [1022:166d]
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4 [1022:166e]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5 [1022:166f]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6 [1022:1670]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7 [1022:1671]
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
02:00.0 Network controller [0280]: MEDIATEK Corp. Device [14c3:0616]
03:00.0 Non-Volatile memory controller [0108]: Sandisk Corp Device [15b7:5017] (rev 01)
04:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Barcelo [1002:15e7] (rev c6)
04:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller [1002:1637]
04:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor [1022:15df]
04:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1 [1022:1639]
04:00.4 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1 [1022:1639]
04:00.5 Multimedia controller [0480]: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor [1022:15e2] (rev 01)
04:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller [1022:15e3]
Output of lsmod | grep mt7921e
mt7921e 28672 0
mt7921_common 114688 1 mt7921e
mt76_connac_lib 90112 2 mt7921e,mt7921_common
mt76 122880 3 mt7921e,mt7921_common,mt76_connac_lib
Output of cat /etc/modprobe.d/mt7921e.conf
alias pci:v000014C3d00000608xsv*sd*bc*sc*i* mt7921e
Output of cat /etc/udev/rules.d/99-mt7921e.rules
SUBSYSTEM=="drivers", DEVPATH=="/bus/pci/drivers/mt7921e", ATTR{new_id}="14c3 0608"
I have noticed that bluetooth isn't working either (i don't know if both problems can be linked).
I am far from being an expert, so any help is welcome. Thanks :)
Update
I updated to ubuntu 22.04, which did not fix the issue (kernel version is 6.2).
The init command of the driver seems to fail : output of journalctl -b | grep -iE '02:00.0|mt7921e'
sept. 06 08:39:52 camille-mmi kernel: pci 0000:02:00.0: [14c3:0616] type 00 class 0x028000
sept. 06 08:39:52 camille-mmi kernel: pci 0000:02:00.0: reg 0x10: [mem 0xfb500000-0xfb5fffff 64bit pref]
sept. 06 08:39:52 camille-mmi kernel: pci 0000:02:00.0: reg 0x18: [mem 0xfb600000-0xfb607fff 64bit]
sept. 06 08:39:52 camille-mmi kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
sept. 06 08:39:52 camille-mmi kernel: pci 0000:02:00.0: Adding to iommu group 10
sept. 06 08:39:52 camille-mmi kernel: mt7921e 0000:02:00.0: ASIC revision: 79220010
sept. 06 08:39:52 camille-mmi systemd-udevd[325]: mt7921e: /etc/udev/rules.d/99-mt7921e.rules:1 Failed to write ATTR{/sys/bus/pci/drivers/mt7921e/new_id}, ignoring: File exists
sept. 06 08:39:55 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 1) timeout
sept. 06 08:39:55 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:39:59 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 2) timeout
sept. 06 08:39:59 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:02 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 3) timeout
sept. 06 08:40:02 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:05 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 4) timeout
sept. 06 08:40:05 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:09 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 5) timeout
sept. 06 08:40:09 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:12 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 6) timeout
sept. 06 08:40:12 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:15 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 7) timeout
sept. 06 08:40:15 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:19 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 8) timeout
sept. 06 08:40:19 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:22 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 9) timeout
sept. 06 08:40:22 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:25 camille-mmi kernel: mt7921e 0000:02:00.0: Message 00000010 (seq 10) timeout
sept. 06 08:40:25 camille-mmi kernel: mt7921e 0000:02:00.0: Failed to get patch semaphore
sept. 06 08:40:26 camille-mmi kernel: mt7921e 0000:02:00.0: hardware init failed
Update 2 I updated my kernel to version 6.5.1, i still have the "No wifi adapter found" error, however the error messages changed :
camille@camille-mmi:~$ journalctl -b | grep -iE '02:00.0|mt7921e'
sept. 06 10:32:51 camille-mmi kernel: pci 0000:02:00.0: [14c3:0616] type 00 class 0x028000
sept. 06 10:32:51 camille-mmi kernel: pci 0000:02:00.0: reg 0x10: [mem 0xfb500000-0xfb5fffff 64bit pref]
sept. 06 10:32:51 camille-mmi kernel: pci 0000:02:00.0: reg 0x18: [mem 0xfb600000-0xfb607fff 64bit]
sept. 06 10:32:51 camille-mmi kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
sept. 06 10:32:51 camille-mmi kernel: pci 0000:02:00.0: Adding to iommu group 10
sept. 06 10:32:53 camille-mmi systemd-udevd[379]: mt7921e: /etc/udev/rules.d/99-mt7921e.rules:1 Failed to write ATTR{/sys/bus/pci/drivers/mt7921e/new_id}, ignoring: File exists
sept. 06 10:32:55 camille-mmi kernel: mt7921e 0000:02:00.0: driver own failed
sept. 06 10:32:55 camille-mmi kernel: mt7921e: probe of 0000:02:00.0 failed with error -5
Update 3 It finally worked after the kernel update and switching off my computer, waiting a few minutes and turning it on again (instead of reboot).
