I recently purchased a new ASUS laptop (ASUS VivoBook 15X K3504ZA-BQ094) and tried installing Ubuntu 24.04 (latest version on the Ubuntu website). During the installation, the connect to Wi-fi option was disabled and even after the installation, I don't have an option to connect to Wi-fi (it's missing in the menu from the upper-right corner). When I try to turn on the Bluetooth from the upper-right corner menu, 3 dots (...) appear over the Bluetooth icon and nothing happens, and if I try to turn it on from the Settings page, the switch automatically turns off.
I connected a phone to the laptop to check for updates and it updated 400MB but nothing about wi-fi (still not showing). In Software Updater there are no more updates and in Software & Updates -> Additional drivers it says no additional drivers available.
Some commands and their results (if it helps):
lspci -nnk | grep 0280 -A3
0000:02:00.0 Network controller [0280]: MEDIATEK Corp. Device [14c3:7902]
DeviceName: WLAN
Subsystem: AzureWave Device [1a3b:5520]
10000:e0:06.0 PCI bridge [0604]: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 [8086:464d] (rev 04)
nmcli device
DEVICE           TYPE      STATE                   CONNECTION
lo               loopback  connected (externally)  lo
EDIT: command from comment
sudo lshw -C network
*-network UNCLAIMED
       description: Network controller
       product: MEDIATEK Corp.
       vendor: MEDIATEK Corp.
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm bus_master cap_list
       configuration: latency=0
       resources: iomemory:600-5ff memory:6000000000-60000fffff memory:84000000-84007fff
The laptop came with No OS, and I'm not dual booting with Windows or anything, just trying to install a functional Ubuntu. If there is anybody that can help me, thanks in advance!
I had a similar issue. I fixed the wifi, but bluetooth still does not toggle on in the settings menu.
Step 1 Get network hardware info
lshw -C network
lspci -k | grep -i network -A 3
09:00.0 Network controller: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] (rev 1a)
    Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
    Kernel modules: iwlwifi
0a:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader (rev 01)
My network hardware was Intel Wi-Fi 6E AX210/AX1675 and my driver was iwlwifi, as you can see from above output. You will need the name of your driver so save this for later.
I tried updating the firmware
sudo apt update
sudo apt install --reinstall linux-firmware
to then reload the wifi module
sudo modprobe -r iwlwifi
sudo modprobe iwlwifi
It was not working so we used
dmesg | grep iwlwifi
Which showed that my system was searching for firmware files between vesrions 39-64. It was a long out put which showed iwlwifi-ty-a0-gf-a0-XX.ucode Where those two bold XX's were numbers between 39-64.
So we check on the firmware files...
ls /lib/firmware/ | grep iwlwifi-ty-a0-gf-a0
iwlwifi-ty-a0-gf-a0-59.ucode.zst iwlwifi-ty-a0-gf-a0-66.ucode.zst iwlwifi-ty-a0-gf-a0-72.ucode.zst iwlwifi-ty-a0-gf-a0-73.ucode.zst iwlwifi-ty-a0-gf-a0-74.ucode.zst iwlwifi-ty-a0-gf-a0-77.ucode.zst iwlwifi-ty-a0-gf-a0-78.ucode.zst iwlwifi-ty-a0-gf-a0-79.ucode.zst iwlwifi-ty-a0-gf-a0-81.ucode.zst iwlwifi-ty-a0-gf-a0-83.ucode.zst iwlwifi-ty-a0-gf-a0-84.ucode.zst iwlwifi-ty-a0-gf-a0-86.ucode.zst iwlwifi-ty-a0-gf-a0.pnvm.zst
Turns out the firmware files were not decompressed they were compressed in.zst format still.
You can decompress the firmwarefiles with
sudo apt install zstd
sudo zstd -d /lib/firmware/iwlwifi-ty-a0-gf-a0-*.zst
Now you can unload and reload the wifi driver
Restart network manager
sudo systemctl restart NetworkManager.service
Then check and see if that resolved the issue
nmcli device wifi list
You should see a list of wifi networks in your area.
