The machine won't wake after suspend.
This happens both when I close the lid, or when I suspend from the power off menu. As far as I can tell, the machine does go in suspend mode - the screen goes dark and built-in keyboard's backlight turns off. However, pressing buttons on the keyboard (even the built-in) or moving the mouse / touching the trackpad does not wake it up.
I don't see anything suspicious in the system log:
Sep 01 08:54:25 machine-Precision-5570 kernel: Low-power S0 idle used by default for system suspend
Sep 01 09:10:33 machine-Precision-5570 kernel: Low-power S0 idle used by default for system suspend
Sep 01 09:14:56 machine-Precision-5570 ModemManager[1261]: <info>  [sleep-monitor-systemd] system is about to suspend
Sep 01 09:14:57 machine-Precision-5570 systemd-sleep[4698]: Entering sleep state 'suspend'...
Sep 01 09:14:57 machine-Precision-5570 kernel: PM: suspend entry (s2idle)
Sep 01 09:16:17 machine-Precision-5570 kernel: Low-power S0 idle used by default for system suspend
I found some posts that claim it's due to nvidia drivers, but I don't have any proprietary drivers installed.
I checked the BIOS but don't see anything relevant.
I tried enabling the USB devices power wakeup feature, but that didn't seem to do anything.
I'm running 22.04 on Dell Precision 5570.
Edit: This appears to be kernel related. 6.2.0-31-generic and 6.2.0-32-generic exhibit the problem, but 5.19.0-50-generic does not - when I load that version of the kernel the machine shuts down just fine.
I'll file a bug report against Ubuntu - maybe updating the kernel would fix the issue, but I don't want to do that before I get some feedback if that's OK.
ventsyv
  • 141
This is a hardware error and not an error on the OS. When the system is in hibernation or suspension pressing a key needs to be picked up by the system itself. Mind that a lot of Dell machines do NOT use wake-on-keyboard. Mine does not, not even in Windows.
Make sure wake-on-keyboard is a feature of your machine.
I found this external source also with a list of supported Dell systems. I don't see a Precision 5570 on this page (but there is an Inspiron 5570).
Rinzwind
  • 309,379
It appears to be a kernel related problem. I was running 6.2.0-32-generic. When I switched to 5.19-50-generic, the issue went away.
I made it permanent by following this answer: https://askubuntu.com/a/1000735/433791
Basically:
sudo cp /etc/default/grub /etc/default/grub.bak
sudo vi /etc/default/grub
Add the following 2 lines to the file
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
Then update the boot file:
sudo update-grub
Restart, then press "esc" when at the manufacturer logo. From the boot menu, select "Advanced" then select the kernel you want. That kernel will now be loaded at boot / restart.
ventsyv
  • 141
I had the same problem, with Ubuntu 20.10 on an HP ProBook laptop. The default startup kernel is 6.11.0-13. When I startup with 6.11.0-12, which is also in the grub menu, suspend does seem to work well. So I changed the grub menu (with Grub Customizer) to use this kernel by default.
