I am embarrassed to ask this question but I can't get into the BIOS of this MB to change the boot order for my Ubuntu server 22.04 installation! In the manual the keys are F2 or Del. I've tried both of these several times without success (starting 'pecking' as soon as I press the start button). I've tried a PS2 Keyboard and a Wireless (not Bluetooth) keyboard. The manual then says to try following if above doesn't work!
  1. Press Ctl+Alt+Delete simultaneously
  2. Press the Reset button on the system chassis
  3. Press the Power button to turn the system off, then back on. Do this option only if you failed to enter BIOS setup using the first two options.
It then says: "After doing either of the three options, press the Del key to enter BIOS."
Just wondering if anyone else has tried any of these 3 options? They seem strange to me, particularly the third. These instructions relate to "after POST", so does that mean after I've logged into Ubuntu server? Am I being too risk averse, as I expect these instructions are mainly directed to Microsoft users?
karel
  • 122,292
  • 133
  • 301
  • 332
cnic023
Section 2.2 in the manual will explain another option to try.
Id also sugest you review the Support page for any BIOS firmware updates.
You can clear the cmos and it should force an error offering to enter BIOS on next boot.There should be two jumper/pins on the board labled CLRTC located right by your front panel header.
Caution Again this will Clear everything and reset the entire BIOS back to factory defaults.
This may help: https://www.reddit.com/r/ASUS/comments/okjfic/why_i_cant_enter_on_bios_i_have_a_b560a_gaming/
BIOS Manual: https://dlcdnets.asus.com/pub/ASUS/mb/LGA1200/PRIME_B560M-A/E18905_PRIME_B560M-A_v2_UM_WEB.pdf
Support page: https://www.asus.com/motherboards-components/motherboards/prime/prime-b560m-a/helpdesk_download/?model2Name=PRIME-B560M-A
PHebert
Thanks for all the helpful suggestions. I think I have a solution but it may be restricted to the B560M-A motherboard. The goal was to change the boot order to enable a USB boot but it was impossible to enter the BIOS by the usual F2 or DEL route before POST because the delay before POST (logo on screen) was too short (but the default is adjustable up to 10 seconds). After POST and login I entered ctrl + alt + delete. This reboots however it does so slower thereby allowing entry of F2 or DEL to 'get into' the BIOS. This is because, after an AC failure (or something similar I guess), 'fast boot' reverts to 'normal boot' for that boot only. Once in BIOS the delay before POST can be adjusted to suit a slow old man like me. My research was helped by an online BIOS Manual for this MB which did not come with the machine: "Prime / TUF Gaming Intel 500 series BIOS Manual".
cnic023
