A little background: I am trying to set up an automated install process in AWS that configures my servers with little intervention. I have it generally working in Ubuntu 18.04. However, in 22.04 (ARM) There are errors.
The problem: Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?
I have implemented the solution above. The issue is that when I run apt list --installed.
I still get: unattended-upgrades/jammy,now 2.8ubuntu1 all [installed,automatic].
In 18.04 the end of that line reads [installed]. Am I able to make the 22.04 version manual so the system sees it as such? I really don't want it to run at all on the first boot. This automated version locks up my ability to continue processing the server until I either reboot it or the process finishes. My automation breaks, where if I do it manually it works.
If I can't have that, I could also use a comment or two on knowing how to know that auto-install has finished on the first boot.
I am noticing that I have to press enter twice during the upgrade process even with the -y flag. Is this part of the issue? Or a different issue?
Thanks All!
UPDATE: My understanding of what is going on in the apt list -installed command is corrected from the comments.
My issues now are:
- Is there a way I can start the process without using sleep and an arbitrary number?
- How do I deal with apt-get upgrade needing me to press enter to continue my custom installations?
