The time to failure is highly variable with the longest operating run being ~13 hours fsck never reports any problems and shutting down before a freeze happens produces a clean restart with no orphaned inodes in the startup sequence. one recovery check of the file system (esc f2 during boot) showed 1 damaged file but I can't get that to replicate. smartctl output to follow:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-75-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION === Model Family: WD Blue / Red / Green SSDs Device Model: WDC WDS500G2B0A-00SM50 Serial Number: 213212806522 LU WWN Device Id: 5 001b44 8bc61fb2d Firmware Version: 415020WD User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5 SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Jun 29 10:35:01 2023 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled
=== START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED
General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 4 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0032 100 100 --- Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 --- Old_age Always - 11839 12 Power_Cycle_Count 0x0032 100 100 --- Old_age Always - 214 165 Block_Erase_Count 0x0032 100 100 --- Old_age Always - 382465936243 166 Minimum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 1 167 Max_Bad_Blocks_per_Die 0x0032 100 100 --- Old_age Always - 64 168 Maximum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 18 169 Total_Bad_Blocks 0x0032 100 100 --- Old_age Always - 268 170 Grown_Bad_Blocks 0x0032 100 100 --- Old_age Always - 0 171 Program_Fail_Count 0x0032 100 100 --- Old_age Always - 0 172 Erase_Fail_Count 0x0032 100 100 --- Old_age Always - 0 173 Average_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 9 174 Unexpected_Power_Loss 0x0032 100 100 --- Old_age Always - 47 184 End-to-End_Error 0x0032 100 100 --- Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 --- Old_age Always - 0 188 Command_Timeout 0x0032 100 100 --- Old_age Always - 0 194 Temperature_Celsius 0x0022 076 040 --- Old_age Always - 24 (Min/Max 11/40) 199 UDMA_CRC_Error_Count 0x0032 100 100 --- Old_age Always - 0 230 Media_Wearout_Indicator 0x0032 005 005 --- Old_age Always - 0x0556005a0556 232 Available_Reservd_Space 0x0033 100 100 004 Pre-fail Always - 100 233 NAND_GB_Written_TLC 0x0032 100 100 --- Old_age Always - 4897 234 NAND_GB_Written_SLC 0x0032 100 100 --- Old_age Always - 21766 241 Host_Writes_GiB 0x0030 253 253 --- Old_age Offline - 16387 242 Host_Reads_GiB 0x0030 253 253 --- Old_age Offline - 5417 244 Temp_Throttle_Status 0x0032 000 100 --- Old_age Always - 0
SMART Error Log Version: 1 No Errors Logged
SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Extended offline Completed without error 00% 11838 -
Selective Self-tests/Logging not supported
mook765
  • 18,644
