60
I have already acquired a S/MIME certificate (a .p12 file) issued by an authority. Using it in Writer, I can digitally sign documents by following this procedure : How do I make a digital certificate available to LibreOffice Writer for digital signatures?
Can I do the same for PDF files? If yes, what method do you suggest me? I would prefer a solution that relies on Free Software.
Pablo Bianchi
  • 17,371
Agmenor
  • 16,394
14 Answers14
26
Your only option is Portable Signer. Download it and run the jar. It requires a private key in a p12 file though (not compatible with SmartCard).
You might expect Ubuntu document signing tools like qdigidoc or gpg would do, but no, they don't play with PDF signatures.
You might then expect Ubuntu PDF manipulation tools like qpdf, which provides encryption, or pdftk, which provides watermarking, to provide signing features too, but, no, they don't.
The total list of opensource tools available for your purpose is: http://wiki.cacert.org/PdfSigning
Unfortunately, none of the tools is currently maintained and none can be found in Ubuntu packages. Portable Signer is the most well maintained of all.
  • Portable Signer hasn't been updated since 2014 - this is the most well maintained among all.
  • jSignPdf hasn't been updated since 2013.
  • jPdfSign hasn't been updated since 2006.
  • CACert's PdfSigner uses outdated iText tool.
  • OpenSignature hasn't been updated since 2008.
  • Footprint's link is broken.
  • jPDFSecure (commercial) – updated in 2017 but it is a Java library not a user tool.
25
Good news! KDE's PDF viewer Okular (with backend Poppler) now supports embedded digital signatures in PDFs, similar to how Adobe Reader does it. Details are found in a post by TU Dresden, who has sponsored the implementation of this feature.
The feature is expected to appear in releases from April 2021 (Okular v21.04, Poppler v21.01). As of December 2020, it is already possible to compile the current development version of Okular and the Poppler PDF library locally to obtain the feature. Instructions and a build script are provided with the TU Dresden post.
I have completed the installation using the instructions in the script (watch out for truncated lines in the online-preview!) on KDE Neon 5.20 (based on Ubuntu 20.04 LTS) using Poppler as of Commit 407293bf and Okular as of Commit 110ccd61 (future versions should of course continue to work, so this is just for full reproducibility). I have installed under /usr/local/ and created a start script okular-sign with the variable definitions as in the TU Dresden manual. The new version of Okular identifies as "Version 21.03.70". As typical for KDE, this "local" version of Okular does interfere with the official one from the distribution, which is partly changed to the new version even when starting the old binary (presumably this is due to KDE's system-wide registration of "parts" or some such component). I hope that it will be possible to revert to an official version when signing support is released in my distribution's packages.
After successful installation, I could create a digital signature as advertised in the post:
  • Open a PDF
  • Click 'Digitally sign' in the 'Tools' menu. Alternatively add the "Digitally sign" icon in your preferred tool bar and click it.
  • Draw a rectangle where you want to have the visible hint for the electronic signature.
  • A dialogue will ask for the private key to use, in case there are multiple. Select the one you want to use.
  • Enter the passphrase of your key.
One is prompted to save the signed PDF under a new file name after that.
mak
  • 381
If you have the certificate available in Writer and if using its Export to PDF function, you can also digitally sign the resulting PDF from the last tab of the dialog right before the export.
As far as I can tell, Acrobat Reader for Android says the document is protected, for what it's worth.
Update '17: Since last December you can sign PDF files with LibreOffice by going File → Digital signatures → Sign Existing PDF.
That will open Draw which is capable of signing the PDF.
Socowi
  • 113
K3---rnc
  • 1,265
17
I found that you can use gpg to sign a PDF in a way that it still opens up in a viewer.
gpg --clearsign --output=signed.pdf input.pdf
Above would yield .asc file which is basically concatenation of input||signature but file extension is forced into .pdf making it to open in viewer, produce thumbnails, etc.
You can verify signature using gpg again.
$ gpg --verify signed.pdf
gpg: Podpisano nie, 12 kwi 2015, 19:07:15 CEST z użyciem RSA kluczem
gpg: Poprawny podpis od "Arkadiusz Bulski <arek.bulski@gmail.com>"
Be warned that some pdfs dont work well with signing this way, such as optimised pdfs. You should check the results yourself.
ArekBulski
  • 1,201
There is a GPL tool called AutoFirma from Spanish Government which works quite nice with p12 formatted certificates. For now it's only available in Spanish, but source code is available here or on Github and could be translated.
geraldo
  • 201
You can sign PDF files with gpg/seahorse.
Learn more: https://help.ubuntu.com/community/GnuPrivacyGuardHowto
You can for instance use OpenSignPDF, that can be download here: http://opensignature.sourceforge.net/english.php
I hope this answers your question.
Agmenor
  • 16,394
Master PDF Editor has a free version that will sign .p12 files.
However the free version leaves an ugly watermark. Interestingly enough, this can be removed within the program itself or with another PDF editor (ex. LibreOffice Draw). I think version 4 does not leave a watermark.
qwr
  • 2,969
I ended up doing following
  1. Installed Virtual Box
  2. Then installed virtual box extension pack (For usb token)
  3. Download windows 10 iso available for free from MS website.
  4. Boot into windows downloaded Adobe reader and signed the document.
Not the native solution but it gets the work done.
MariusSiuram
  • 207
  • 13
Mr Coder
  • 640
Using LibreOffice with version bigger than 5.3 you can sign PDF documents.
Go To File > Digital Signatures > Sign existing PDF... The original entry dated from December 2016: https://vmiklos.hu/blog/pdf-sign.html
cheche
  • 376
As @fquinto mentioned in a comment:
jsignpdf is a solid option.
PDF signing software written in Java. It supports visible signatures, timestamping, certificate verification and many other cool features
Mahmoud
  • 901
Since google led me here. These are my steps without p12 formatted certificate. based on how to get p12 formatted client certificate file and how to sign documents .
  1. register on cacert.org via join https://www.cacert.org/index.php?id=1
  2. get client certificate as described in the cacert wiki:
  3. backup the client certificate as p12 formatted file (make sure to keep the backup password. You will need it later)
  4. install PortableSigner
  5. run PortableSigner
    • sudo /usr/local/PortableSigner/PortableSigner.sh
  6. use GUI to set
    • input file
    • output file name
    • signature file (your newly exported client certificate as p12 formatted file)
    • password is the backup password you set when creating the p12 formatted file.
  7. Click "Ok" to create signed document.
Amanda
  • 340
You may also want to take a look at my Simple Signer. In addition to LibreOffice Draw, it can also add a visual stamp onto the document (which is linked to your signature) as known from the Adobe Reader.
In addition to that, you can choose if you want to sign or certify your document.
PDF Studio 7 Pro, available in the Software Center, features digital signing of PDFs. As of when I am writing it costs only 125 $.
According to the official website, it is indeed S/MIME signing.
Agmenor
  • 16,394
I met the same problem, and I build a small tool based on Pyhanko. It is here:
Github
It's open-source and single-file. It has English CLI and Chinese-English bilingual QR code result.
You just need to fill your information in stamp.py, then it's OK.
If you want to change the location of stamp, change Line 50 in stamp.py
More information: My Blog
Micraow
