I recently bought Huawei MateBook d16 (on intel i5 12450H, LPDDR4x) and did clean install of Ubuntu 23.04.
Everything is great except when I resume from suspend or when I reopen the lid, the OS either freezes or it completely crashes.
Things I tried to fix this after googling:
  1. Turning off Bluetooth in BIOS
  2. Turning off Fingerprint Scanner in BIOS
  3. Setting BIOS Setting "Other Wakeup Source" to Disabled
  4. Setting BIOS Setting "Virtualization Technology" to Disabled
  5. sudo apt-get dist-upgrade
  6. Updating Intel graphics drivers
  7. Following this post https://askubuntu.com/a/1009393/1705081
System-info
Starting the Ubuntu Forums 'system-info' Report: 2023-06-15  13:07:31 MSK (+0300)
    Part of the Ama-gi Project
    Version: 02.00-08, Script Date: 2023.05.24
Main Complaint: Crash after suspend Problem Description: Laptop crashes after waking from suspend or reopening the lid ---------- General Computer Specifications:
--- Computer/CPU Information from 'lshw -C cpu' --- *-Cpu Description: CPU Product: 12th Gen Intel(R) Core(TM) i5-12450H Vendor: Intel Corp. Physical id: 4 Bus info: cpu@0 Version: 6.154.3 Slot: CPU0 Size: 4150MHz Capacity: 4400MHz Width: 64 bits Clock: 100MHz Capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabilities cpufreq Configuration: cores=8 enabledcores=8 microcode=1065 threads=12
computer Description: Notebook Product: RLEF-XX (C170) Vendor: HUAWEI Version: M1010 Serial: [REMOVED] Width: 64 bits Capabilities: smbios-3.4.0 dmi-3.4.0 smp vsyscall32 Configuration: chassis=notebook family=MateBook D sku=C170 uuid=[REMOVED]
------------------ SMBIOS Information from '/sys/class/dmi/id/' Bios Vendor: HUAWEI Bios Version: 1.24 Bios Release: 1.24 Board Vendor: HUAWEI Board Name: RLEF-XX-PCB Board Version: M1010 Board Serial: PM04C02327000241 Board Asset Tag: N/A
Current boot mode: UEFI Firmware mode --- SecureBoot Status from 'mokutil': SecureBoot disabled Platform is in Setup Mode
---------- Memory Information: total used free shared buff/cache available Mem: 15703 2996 10981 701 2751 12707 Swap: 4095 0 4095
---------- Swap Information: --- Info from 'fstab' /swap.img none swap sw 0 0
--- Info from '/proc/swaps' Filename Type Size Used Priority /swap.img file 4194300 0 -2
--- System Swapiness Settings Valid swappiness settings are from 10 - 60 . Current setting in '/proc/sys/vm/swappiness': 60 Current configuration setting in '/etc/sysctl.conf file:
---------- IP Address Information: --- IP Address Information from 'ip addr' --- 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 inet [REMOVED] inet6 [REMOVED] 2: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000 inet [REMOVED] inet6 [REMOVED]
--- Internet Connection Status from 'ping [various addresses]' --- Connected to Internet with DNS
--- Network Device Status Summary from 'ip addr' ---
These Network Devices are up: 2: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
For more detailed wireless information, get and run the script at https://github.com/UbuntuForums/wireless-info
--- Hostname from 'hostname --fqdn' ---
The 'Hostname' of the computer system is: kostya-RLEF-XX
---------- Storage Controller Information From 'lspci': 01:00.0 Non-Volatile memory controller: Silicon Motion, Inc. Device 1001 (rev 03) (prog-if 02 [NVM Express]) Subsystem: Silicon Motion, Inc. Device 2262 Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0 Memory at 80400000 (64-bit, non-prefetchable) [size=16K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+ Capabilities: [70] Express Endpoint, MSI 00 Capabilities: [b0] MSI-X: Enable+ Count=16 Masked- Capabilities: [100] Advanced Error Reporting Capabilities: [158] Secondary PCI Express Capabilities: [178] Latency Tolerance Reporting Capabilities: [180] L1 PM Substates Kernel driver in use: nvme Kernel modules: nvme
---------- File system specs from 'df -h': Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/ubuntu--vg-ubuntu--lv ext4 466G 31G 411G 7% / /dev/nvme0n1p2 ext4 2,0G 110M 1,7G 6% /boot /dev/nvme0n1p1 vfat 1,1G 18M 1,1G 2% /boot/efi
---------- Disk/Partition Information From 'fdisk':
Disk /dev/nvme0n1: 476,94 GiB, 512110190592 bytes, 1000215216 sectors Disk model: PCIe-8 SSD 512GB
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 42DB227A-088A-3A4D-8BBB-3B847CA7CF92
Device Start End Sectors Size Type /dev/nvme0n1p1 2048 2203647 2201600 1G EFI System /dev/nvme0n1p2 2203648 6397951 4194304 2G Linux filesystem /dev/nvme0n1p3 6397952 1000212479 993814528 473,9G Linux filesystem
Disk /dev/mapper/ubuntu--vg-ubuntu--lv: 473,89 GiB, 508831989760 bytes, 993812480 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
---------- Disk/Partition Information From 'lsblk': NAME SIZE FSTYPE LABEL MOUNTPOINT MODEL nvme0n1 476,9G PCIe-8 SSD 512GB |_nvme0n1p1 1G vfat /boot/efi
|_nvme0n1p2 2G ext4 /boot
|_nvme0n1p3 473,9G LVM2_member
-ubuntu--vg-ubuntu--lv 473,9G ext4 / ------- 'lsblk' information continued ... NAME HOTPLUG PARTUUID UUID nvme0n1 0 |_nvme0n1p1 0 99abc21d-3f67-ef4f-ae10-e59f0df7b373 D6EC-709C |_nvme0n1p2 0 00a2e2a9-a300-674a-9a5a-5fcd329a48e6 d3f1a5bb-9ab6-45cb-9937-97d350568cd9 |_nvme0n1p3 0 f2898fdb-4a1a-1e4c-a25a-10814eeed9df YaiNwF-7N5E-lW7X-08kH-3hDQ-Qv0S-VF9ePY-ubuntu--vg-ubuntu--lv 0 f8ec66d3-dd3d-4363-b5cc-9cf6a5728c78
---------- BTRFS Information: There are no BTRFS vdev's present.
---------- LVM2 Information: LVM2 is installed.
PV VG Fmt Attr PSize PFree DevSize PV UUID
/dev/nvme0n1p3 ubuntu-vg lvm2 a-- <473,89g 0 <473,89g YaiNwF-7N5E-lW7X-08kH-3hDQ-Qv0S-VF9ePY
PV /dev/nvme0n1p3 VG ubuntu-vg lvm2 [<473,89 GiB / 0 free] Total: 1 [<473,89 GiB] / in use: 1 [<473,89 GiB] / in no VG: 0 [0 ]
--- Physical volume --- PV Name /dev/nvme0n1p3 VG Name ubuntu-vg PV Size <473,89 GiB / not usable 0
Allocatable yes (but full) PE Size 4,00 MiB Total PE 121315 Free PE 0 Allocated PE 121315 PV UUID YaiNwF-7N5E-lW7X-08kH-3hDQ-Qv0S-VF9ePY
--- Physical Segments --- Physical extent 0 to 121314: Logical volume /dev/ubuntu-vg/ubuntu-lv Logical extents 0 to 121314
VG Attr Ext #PV #LV #SN VSize VFree VG UUID VProfile ubuntu-vg wz--n- 4,00m 1 1 0 <473,89g 0 LmjELv-n8Bh-eOxo-mUop-Mz8J-HIl9-TXIhO5
Found volume group "ubuntu-vg" using metadata type lvm2
--- Volume group --- VG Name ubuntu-vg System ID
Format lvm2 Metadata Areas 1 Metadata Sequence No 2 VG Access read/write VG Status resizable MAX LV 0 Cur LV 1 Open LV 1 Max PV 0 Cur PV 1 Act PV 1 VG Size <473,89 GiB PE Size 4,00 MiB Total PE 121315 Alloc PE / Size 121315 / <473,89 GiB Free PE / Size 0 / 0
VG UUID LmjELv-n8Bh-eOxo-mUop-Mz8J-HIl9-TXIhO5
--- Logical volume --- LV Path /dev/ubuntu-vg/ubuntu-lv LV Name ubuntu-lv VG Name ubuntu-vg LV UUID turVcM-I8Rh-3lHj-eZxH-qI5b-gGnw-adsHoX LV Write Access read/write LV Creation host, time ubuntu, 2023-03-20 17:28:10 +0300 LV Status available
open 1
LV Size <473,89 GiB Current LE 121315 Segments 1 Allocation inherit Read ahead sectors auto
  • currently set to 256
Block device 253:0
--- Physical volumes --- PV Name /dev/nvme0n1p3
PV UUID YaiNwF-7N5E-lW7X-08kH-3hDQ-Qv0S-VF9ePY PV Status allocatable Total PE / Free PE 121315 / 0
LV Type Devices
ubuntu-lv linear /dev/nvme0n1p3(0)
ACTIVE '/dev/ubuntu-vg/ubuntu-lv' [<473,89 GiB] inherit
open 1
Block device 253:0
---------- mdadm RAID Information: No active md devices present. ---------- Mount Details of '/etc/fstab': /dev/disk/by-id/dm-uuid-LVM-LmjELvn8BheOxomUopMz8JHIl9TXIhO5turVcMI8Rh3lHjeZxHqI5bgGnwadsHoX / ext4 defaults 0 1 /dev/disk/by-uuid/d3f1a5bb-9ab6-45cb-9937-97d350568cd9 /boot ext4 defaults 0 1 /dev/disk/by-uuid/D6EC-709C /boot/efi vfat defaults 0 1 /swap.img none swap sw 0 0
---------- Current Mount Details of 'mount': /dev/mapper/ubuntu--vg-ubuntu--lv on / type ext4 (rw,relatime) /dev/mapper/ubuntu--vg-ubuntu--lv on /var/snap/firefox/common/host-hunspell type ext4 (ro,noexec,noatime) /dev/nvme0n1p1 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) /dev/nvme0n1p2 on /boot type ext4 (rw,relatime)
For more detailed disk Information, please run the 'boot-info' script from: (STABLE) https://launchpad.net/~yannubuntu/+archive/ubuntu/boot-repair
---------- USB Information from 'lsusb -t -v': /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M ID 1d6b:0003 Linux Foundation 3.0 root hub /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/3p, 20000M/x2 ID 1d6b:0003 Linux Foundation 3.0 root hub /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M ID 1d6b:0002 Linux Foundation 2.0 root hub |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M ID 046d:c542 Logitech, Inc. |__ Port 7: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M ID 0408:1060 Quanta Computer, Inc. |__ Port 7: Dev 3, If 2, Class=Application Specific Interface, Driver=, 480M ID 0408:1060 Quanta Computer, Inc. |__ Port 7: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M ID 0408:1060 Quanta Computer, Inc. /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M ID 1d6b:0002 Linux Foundation 2.0 root hub
---------- Video Details from 'lshw':
*-display description: VGA compatible controller product: Alder Lake-P GT1 [UHD Graphics] vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 logical name: /dev/fb0 version: 0c width: 64 bits clock: 33MHz capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb configuration: depth=32 driver=i915 latency=0 mode=1920x1200 resolution=1920,1200 visual=truecolor xres=1920 yres=1200 resources: iomemory:600-5ff iomemory:400-3ff irq:155 memory:6000000000-6000ffffff memory:4000000000-400fffffff ioport:3000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
--- Graphics Environment Continued from 'various graphics ENVs' ---- The Current Configured Destop is: ubuntu:GNOME The Current Desktop Session is: ubuntu The Current X Desktop Information Details from 'xrandr' are: Screen 0: minimum 16 x 16, current 1920 x 1200, maximum 32767 x 32767 XWAYLAND0 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 350mm x 220mm The Current Session Type is: wayland The Current Display Manager is: gdm3 The Current Desktop Theme: 'Yaru-viridian' The Current Virtual TTY's being used are: TTY# Used By tty2 gdm-wayland-ses tty2 gnome-session-b pts/0 bash pts/1 system-info pts/1 system-info pts/1 sed pts/1 system-info pts/1 ps pts/1 awk
---------- Sound Device Information From 'lspci': 00:1f.3 Multimedia audio controller: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01) Subsystem: Huawei Technologies Co., Ltd. Alder Lake PCH-P High Definition Audio Controller Flags: bus master, fast devsel, latency 32, IRQ 156 Memory at 6001138000 (64-bit, non-prefetchable) [size=16K] Memory at 6001000000 (64-bit, non-prefetchable) [size=1M] Capabilities: [50] Power Management version 3 Capabilities: [80] Vendor Specific Information: Len=14 <?> Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+ Kernel driver in use: sof-audio-pci-intel-tgl Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
For more detailed audio information, get and run the script at: http://www.alsa-project.org/alsa-info.sh
---------- Repository Information from '/etc/apt/sources.list and etc/apt/sources.list.d/':
Sources List: deb http://archive.ubuntu.com/ubuntu lunar main restricted deb http://archive.ubuntu.com/ubuntu lunar-updates main restricted deb http://archive.ubuntu.com/ubuntu lunar universe deb http://archive.ubuntu.com/ubuntu lunar-updates universe deb http://archive.ubuntu.com/ubuntu lunar multiverse deb http://archive.ubuntu.com/ubuntu lunar-updates multiverse deb http://archive.ubuntu.com/ubuntu lunar-backports main restricted universe multiverse deb http://archive.ubuntu.com/ubuntu lunar-security main restricted deb http://archive.ubuntu.com/ubuntu lunar-security universe deb http://archive.ubuntu.com/ubuntu lunar-security multiverse
Sources List from SourcesD: /etc/apt/sources.list.d/steam-stable.list.save: deb [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] https://repo.steampowered.com/steam/ stable steam deb-src [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] https://repo.steampowered.com/steam/ stable steam /etc/apt/sources.list.d/steam-beta.list.save: File had no entries. /etc/apt/sources.list.d/oibaf-ubuntu-graphics-drivers-lunar.list: deb https://ppa.launchpadcontent.net/oibaf/graphics-drivers/ubuntu/ lunar main /etc/apt/sources.list.d/steam-stable.list: deb [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] https://repo.steampowered.com/steam/ stable steam deb-src [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] https://repo.steampowered.com/steam/ stable steam /etc/apt/sources.list.d/vscode.list.save: deb [arch=amd64,arm64,armhf] http://packages.microsoft.com/repos/code stable main /etc/apt/sources.list.d/google-chrome.list: deb [arch=amd64] https://dl.google.com/linux/chrome/deb/ stable main /etc/apt/sources.list.d/steam-beta.list: File had no entries. /etc/apt/sources.list.d/oibaf-ubuntu-graphics-drivers-lunar.list.save: deb https://ppa.launchpadcontent.net/oibaf/graphics-drivers/ubuntu/ lunar main /etc/apt/sources.list.d/google-chrome.list.save: deb [arch=amd64] https://dl.google.com/linux/chrome/deb/ stable main /etc/apt/sources.list.d/vscode.list: deb [arch=amd64,arm64,armhf] http://packages.microsoft.com/repos/code stable main
---------- KeyMap and Locale Information from from various sources: --- Keymap Info from 'setxkbmap' ---- WARNING: Running setxkbmap against an XWayland server rules: evdev model: pc105 layout: us
--- Locale Info from 'localectl' ---- System Locale: LANG=en_US.UTF-8 LANGUAGE=en LC_NUMERIC=ru_RU.UTF-8 LC_TIME=ru_RU.UTF-8 LC_MONETARY=ru_RU.UTF-8 LC_PAPER=ru_RU.UTF-8 LC_NAME=ru_RU.UTF-8 LC_ADDRESS=ru_RU.UTF-8 LC_TELEPHONE=ru_RU.UTF-8 LC_MEASUREMENT=ru_RU.UTF-8 LC_IDENTIFICATION=ru_RU.UTF-8 VC Keymap: (unset) X11 Layout: gb X11 Model: pc105
---------- Other Details from 'Various': The current kernel version is: 6.2.0-20-generic --- Operating System Release Description --- The current release description is: Ubuntu 23.04
Original Installation Date: 2023-03-20+17:21:47 Original Installation Media: Ubuntu 23.04 "Lunar Lobster" - Release amd64 (20230418) Do-Release-Upgrade Date: This system may have not had a 'Release Upgrade' through 'do-release-upgrade'
--- Hardware Enablement Stack (HWE) Informationt: These are the current kernel ranges for HWE kernels for this release. --- HWE Kernel Reference from 'apt-cache show': For HWE Package: linux-image-generic-hwe-22.04, Kernel Version: 6.2.0.20.20
--- HWE Package Status from 'dpkg': Package linux-generic-hwe-22.04 is installed.
--- Certified Hardware Platform Status: (By the Ubuntu Wiki Standards) Ubuntu Certified Hardware Platform. Safe to install the Hardware Enablement Stack (HWE).
--- User Installed Package List: bsdutils cloud-init code dash diffutils efibootmgr findutils fonts-indic gnome-user-docs-ru google-chrome-stable grep grub-efi-amd64 grub-efi-amd64-signed gzip hostname hunspell-en-au hunspell-en-ca hunspell-en-gb hunspell-en-za hyphen-en-ca hyphen-en-gb hyphen-en-us hyphen-ru ibus-table-cangjie-big ibus-table-cangjie3 ibus-table-cangjie5 init language-pack-en language-pack-en-base language-pack-gnome-en language-pack-gnome-en-base language-pack-gnome-ru language-pack-gnome-ru-base language-pack-ru language-pack-ru-base libc6 libc6:i386 libchewing3 libchewing3-data libegl1 libegl1:i386 libgbm1 libgbm1:i386 libgl1 libgl1-mesa-dri libgl1-mesa-dri:i386 libgl1:i386 libm17n-0 libmarisa0 libopencc-data libopencc1.1 libotf1 libpinyin-data libpinyin15 libreoffice-help-common libreoffice-help-en-gb libreoffice-help-en-us libreoffice-help-ru libreoffice-l10n-en-gb libreoffice-l10n-en-za libreoffice-l10n-ru linux-generic-hwe-22.04 login lvm2 m17n-db mythes-en-au mythes-en-us mythes-ru ncurses-base ncurses-bin shim-signed steam-launcher steam-libs-amd64 steam-libs-i386:i386 thunderbird-locale-en thunderbird-locale-en-gb thunderbird-locale-en-us thunderbird-locale-ru thunderbird-locale-zh-hant ubuntu-desktop ubuntu-desktop-minimal ubuntu-minimal ubuntu-standard ubuntu-wallpapers util-linux util-linux-extra wbritish wpasupplicant zoom
--- Installed Snap Package List: bare bovo core18 core22 firefox gnome-42-2204 gnome-extension-manager gtk-common-themes kf5-5-106-qt-5-15-9-core22 snap-store snapd snapd-desktop-integration vlc
--- Installed Flatpak Package List: Flatpak is not installed
Currently logged in User(s): NAME LINE TIME COMMENT kostya seat0 2023-06-15 11:42 (login screen) kostya tty2 2023-06-15 11:42 (tty2)
The User running this script was: kostya uid=1000(kostya) gid=1000(kostya) groups=1000(kostya),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev), 100(users),118(lpadmin)
The 'system-info' script was booted from an installed system
The 'system-info' script seems to be running locally
The Linux Kernel Command Line use to boot was: BOOT_IMAGE=/vmlinuz-6.2.0-20-generic root=/dev/mapper/ubuntu--vg-ubuntu--lv ro quiet splash vt.handoff=7
---- Required Programs For Report. --- Some Programs This Script Uses Were Missing --- pastebinit
karel
  • 122,292
  • 133
  • 301
  • 332
I replaced the SSD and now suspend works!
