enter image description here Mouse trails in Windows
I found this question, but it is about Compiz, which is not actively developed anymore.
How to use mouse trails in recent versions Ubuntu (let's say, 22.04 LTS)?
I am looking for answers for both GNOME and KDE, and something which preferably work in both X.Org and Wayland.
For GNOME (Ubuntu):
Install and use the xinput command-line tool by running the following command:
sudo apt install xinput
Use the xinput command to enable mouse trails. Open a terminal and run the following command to list the available input devices:
xinput list
Identify the ID of your mouse device in the list.
Run the following command, replacing with the ID of your mouse device:
xinput set-prop <device-id> 'libinput Pointer Accel Profile Enabled' 0, 1
This command disables the default pointer acceleration and enables a custom profile that creates the mouse trail effect. You may need to experiment with different values to achieve the desired effect.
Arun T
  • 101
