I have a Linux PC (ubuntu 22.04) with a network layout as below:
Internet <-> Router <-> PC <-> edge device <-> Switch <-> APs <-> devices
And with two Lan interfaces as below:
  • eno1: Connected to the internet (directly connected to the router), gets IP: 192.168.1.165 from the router (DHCP)
  • enx3c: connected to an edge device and that edge device is connected to a switch, also so many devices are connected to that switch.
I want clients connected to enx3c to have access to the internet on eno1. And also I need to be able to directly communicate with devices under the enx3c interface.
I have followed suggestions in here and so many other tutorials and questions to see how to forward traffic from one interface to another using iptables as follows:
echo 1 > /proc/sys/net/ipv4/ip_forward
sudo vim /etc/sysctl.conf
net.ipv4.ip_forward=1
sudo sysctl -p
iptables -A FORWARD -i eno1 -o enx3c -j ACCEPT iptables -A FORWARD -i enx3c -o eno1 -m state –state ESTABLISHED,RELATED -j ACCEPT iptables -t nat -A POSTROUTING -o eno1 -j MASQUERADE
After doing so, the edge device didn't get any IP, so I set up a DHCP server on the PC with the below steps:
sudo apt install isc-dhcp-server
sudo vim /etc/dhcp/dhcpd.conf
    subnet 192.168.137.0 netmask 255.255.255.0 {
    default-lease-time 600;
    max-lease-time 7200;
    authoritative;
    range 192.168.137.1 192.168.137.200;
    option routers 192.168.137.254;
    option domain-name-servers 192.168.137.1, 192.168.137.2;
sudo vim /etc/default/isc-dhcp-server INTERFACESv4="enx3c" #so the DHCP server produces Ips for clients connected to the second interface
sudo systemctl start isc-dhcp-server
And the eno1 interface is set to DHCP to get dynamic IP from the router and enx3c is set to manual to get static IP (192.168.137.1).
After starting the DHCP server, the edge device gets an IP in the range, and nmap shows it among live hosts, But there is no access to it! I cannot ping it or ssh into it. And the edge device doesn't have any internet access.
I looked everywhere and it seems that this method must work but I don't know what I am doing wrong. I appreciate any suggestions.
Update: It's worth mentioning that using the answer in here, I used the share to other networks option in the network manager in Ubuntu on the second interface, and after that, it gets IP in a different range, 10.42.0.1/24, and also the edge device gets a new IP in this range, 10.42.0.162, But again, I cannot ping or ssh into this device.
Here is the output for routing tables:
route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    100    0        0 eno1
10.42.0.0       0.0.0.0         255.255.255.0   U     101    0        0 enx3c
169.254.0.0     0.0.0.0         255.255.0.0     U     1000   0        0 eno1
192.168.1.0     0.0.0.0         255.255.255.0   U     100    0        0 eno1
Firouziam
  • 817
  • 22
