I have been trying to connect my headphones or my phone to the computer but it always get stuck on Searching for devices... I have tried to apply this thread solution but the second file is unavailable and looks like there is no other backup file on the internet. My outputs are:
sudo service bluetooth status:
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: active (running) since Thu 2023-05-11 19:25:03 CST; 19min ago
       Docs: man:bluetoothd(8)
   Main PID: 965 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 18961)
     Memory: 1.9M
        CPU: 126ms
     CGroup: /system.slice/bluetooth.service
             └─965 /usr/lib/bluetooth/bluetoothd
may 11 19:25:03 frankusky-Precision-M4800 systemd[1]: Starting Bluetooth service... may 11 19:25:03 frankusky-Precision-M4800 bluetoothd[965]: Bluetooth daemon 5.64 may 11 19:25:03 frankusky-Precision-M4800 systemd[1]: Started Bluetooth service. may 11 19:25:03 frankusky-Precision-M4800 bluetoothd[965]: Starting SDP server may 11 19:25:03 frankusky-Precision-M4800 bluetoothd[965]: Bluetooth management interface 1.22 initialized
sudo dmesg | grep -i bluetooth:
[    4.078951] NET: Registered PF_BLUETOOTH protocol family
[    4.078952] Bluetooth: HCI device and connection manager initialized
[    4.078955] Bluetooth: HCI socket layer initialized
[    4.078957] Bluetooth: L2CAP socket layer initialized
[    4.078960] Bluetooth: SCO socket layer initialized
[    4.207441] Bluetooth: hci0: BCM: chip id 63
[    4.208445] Bluetooth: hci0: BCM: features 0x07
[    4.224452] Bluetooth: hci0: frankusky-Precision-M4800
[    4.224460] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[    4.232456] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[    4.232492] Bluetooth: hci0: BCM: 'brcm/BCM20702A1-413c-8143.hcd'
[    4.232512] Bluetooth: hci0: BCM: 'brcm/BCM-413c-8143.hcd'
[    6.159869] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    6.159874] Bluetooth: BNEP filters: protocol multicast
[    6.159879] Bluetooth: BNEP socket layer initialized
[   32.520607] Bluetooth: RFCOMM TTY layer initialized
[   32.520617] Bluetooth: RFCOMM socket layer initialized
[   32.520624] Bluetooth: RFCOMM ver 1.11
[   43.035687] Bluetooth: hci0: Opcode 0x 402 failed: -22
sudo lsusb; uname -a; lsmod | grep bluetooth; dmesg | grep -i firmware:
us 002 Device 004: ID 0a5c:5800 Broadcom Corp. BCM5880 Secure Applications Processor
Bus 002 Device 003: ID 413c:8143 Dell Computer Corp. Broadcom BCM20702A0 Bluetooth
Bus 002 Device 002: ID 8087:8000 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0c45:649d Microdia Laptop_Integrated_Webcam_HD
Bus 001 Device 002: ID 8087:8008 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Linux frankusky-Precision-M4800 5.19.0-41-generic #42~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue Apr 18 17:40:00 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
bluetooth             827392  42 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic           16384  2 bluetooth
dmesg: read kernel buffer failed: Operation not permitted
Frankusky
  • 103
