I am trying to install a real kernel that I need for an application (controlling a UR robot) and I followed the UR driver tutorial on git hub on how to install it.
First I ran the command:
$ uname -r
5.15.0-69-generic
Infact I run -a to show it all.
$ uname -a
Linux Hamza 5.15.0-69-generic #76~20.04.1-Ubuntu SMP Mon Mar 20 15:54:19 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
I also have a Intel® Core™ i5.
I now want to install a version close to my version which is version 5.14.2. Here are all the commands I do:
mkdir ~/kernel
cd ~/kernel
wget https://cdn.kernel.org/pub/linux/kernel/projects/rt/5.14/patch-5.14.2-rt21.patch.xz
wget https://cdn.kernel.org/pub/linux/kernel/projects/rt/5.14/patch-5.14.2-rt21.patch.sign
wget https://mirrors.edge.kernel.org/pub/linux/kernel/v5.x/linux-5.14.2.tar.xz
wget https://mirrors.edge.kernel.org/pub/linux/kernel/v5.x/linux-5.14.2.tar.sign
xz -dk patch-5.14.2-rt21.patch.xz
xz -d linux-5.14.2.tar.xz
Then there is the verification step which I skipped.
tar xf linux-5.14.2.tar
cd linux-5.14.2
xzcat ../patch-5.14.2-rt21.patch.xz | patch -p1
make oldconfig
Here I press 4 for Fully Preemptible Kernel (RT) (PREEMPT_RT_FULL) (NEW) and for the rest I press enter.
I in the end build the kernel:
make -j `getconf _NPROCESSORS_ONLN` deb-pkg
The error I get:
make[2]: *** [debian/rules:7: build-arch] Error 2
dpkg-buildpackage: error: debian/rules binary subprocess returned exit status 2
make[1]: *** [scripts/Makefile.package:77: deb-pkg] Error 2
make: *** [Makefile:1569: deb-pkg] Error 2
And here are the different warnings I get during the compilation.
dpkg-source: warning: source directory 'linux-5.14.2' is not <sourcepackage>-<upstreamversion> 'linux-upstream-5.14.2-rt21'
dpkg-source: warning: .orig directory name linux-5.14.2.orig is not <package>-<upstreamversion> (wanted linux-upstream-5.14.2-rt21.orig)
dpkg-source: warning: ignoring deletion of file .scmversion
dpkg-source: warning: the diff modifies the following upstream files:
dpkg-source: warning: missing information for output field Standards-Version
arch/x86/hyperv/hv_apic.c:240:1: warning: the frame size of 1032 bytes is larger than 1024 bytes [-Wframe-larger-than=]
fs/jffs2/xattr.c:887:1: warning: the frame size of 1144 bytes is larger than 1024 bytes [-Wframe-larger-than=]887 | }
I really hope someone can see where I went wrong or has a better method for installing because other solutions such as these did not work; One,two and this very recent one but no answers
I had the same issue, the following worked for me (Ubuntu 20 and kernel 5.15.79):
  1. Edit .config file, comment out CONFIG_DEBUG_INFO_BTF, and remove values from CONFIG_MODULE_SIG_KEY, CONFIG_SYSTEM_TRUSTED_KEYS, CONFIG_SYSTEM_REVOCATION_KEYS
  2. If compilation fails again, comment out CONFIG_MODULE_SIG_FORCE and CONFIG_MODULE_SIG_ALL in the .config file.
The parameters to edit I got from these manuals:
sotirov
  • 4,379
ivan_p
