I need to install a RealTime Kernel for working with ROS2 and I have followed this guide very carefully. But I get always the same error:
make[2]: *** [debian/rules:6: build] Errore 2
dpkg-buildpackage: Errore: debian/rules build subprocess returned exit status 2
make[1]: *** [scripts/Makefile.package:77: deb-pkg] Errore 2
make: *** [Makefile:1464: deb-pkg] Errore 2
For instance the passages that I have used on the terminal are the following:
- Create a new folder and enter in the folder:
mkdir kernel && cd kernel - Download the kernel and the patch:
wget https://mirrors.edge.kernel.org/pub/linux/kernel/v5.x/linux-5.4.78.tar.gzandwget http://cdn.kernel.org/pub/linux/kernel/projects/rt/5.4/older/patch-5.4.78-rt44.patch.gz - Unpack and Unzip the two archives:
tar -xzf linux-5.4.78.tar.gzandgunzip patch-5.4.78-rt44.patch.gz - Enter in the kernel folder:
cd linux-5.4.78 - Patching the file:
patch -p1 < ../patch-5.4.78-rt44.patch - Using the old configure, in this case I had 2 configs so I have used:
cp /boot/config-$(uname -r) .configfor my case$(uname -r)is5.4.0-70-generic - Added in the settings of Updates the source code as source and installed other dependencies as written in the guide
- Enable configurations:
yes '' | make oldconfig - Enable the different settings in the menu after:
make menuconfig - The error happen during the making with:
make -jnprocdeb-pkg
How can I solve?
Part of the output (warnings and errors are here):
scripts/kconfig/conf --syncconfig Kconfig
make clean
CLEAN arch/x86/purgatory
CLEAN arch/x86/realmode/rm
CLEAN arch/x86/kernel/cpu
CLEAN arch/x86/entry/vdso
CLEAN kernel/debug/kdb
CLEAN kernel
CLEAN usr
CLEAN fs/unicode
CLEAN arch/x86/tools
sh ./scripts/package/mkdebian
TAR linux-5.4.78-rt44.tar.gz
origversion=$(dpkg-parsechangelog -SVersion |sed 's/-[^-]*$//');\
mv linux-5.4.78-rt44.tar.gz ../linux-5.4.78-rt44_${origversion}.orig.tar.gz
dpkg-buildpackage -r"fakeroot -u" -a$(cat debian/arch) -i.git -us -uc
dpkg-buildpackage: Informazioni: Pacchetto sorgente linux-5.4.78-rt44
dpkg-buildpackage: Informazioni: Versione sorgente 5.4.78-rt44-1
dpkg-buildpackage: Informazioni: Distribuzione sorgente focal
dpkg-buildpackage: Informazioni: Sorgente modificata da kappa95 <kappa95@kappa95-asus-laptop-x505za>
dpkg-buildpackage: Informazioni: Architettura host amd64
dpkg-source -i.git --before-build .
fakeroot -u debian/rules clean
rm -rf debian/*tmp debian/files
make clean
dpkg-source -i.git -b .
dpkg-source: Informazioni: using source format '1.0'
dpkg-source: Avviso: source directory 'linux-5.4.78' is not <sourcepackage>-<upstreamversion> 'linux-5.4.78-rt44-5.4.78-rt44'
dpkg-source: Avviso: .orig directory name linux-5.4.78.orig is not <package>-<upstreamversion> (wanted linux-5.4.78-rt44-5.4.78-rt44.orig)
dpkg-source: Informazioni: building linux-5.4.78-rt44 using existing linux-5.4.78-rt44_5.4.78-rt44.orig.tar.gz
dpkg-source: Informazioni: building linux-5.4.78-rt44 in linux-5.4.78-rt44_5.4.78-rt44-1.diff.gz
dpkg-source: Avviso: ignoring deletion of file .scmversion
dpkg-source: Avviso: the diff modifies the following upstream files:
.clang-format
.cocciconfig
.config.old
.get_maintainer.ignore
.mailmap
CREDITS
MAINTAINERS
README
dpkg-source: Informazioni: use the '3.0 (quilt)' format to have separate and documented changes to upstream files, see dpkg-source(1)
dpkg-source: Informazioni: building linux-5.4.78-rt44 in linux-5.4.78-rt44_5.4.78-rt44-1.dsc
dpkg-source: Avviso: missing information for output field Standards-Version
debian/rules build
make KERNELRELEASE=5.4.78-rt44 ARCH=x86 KBUILD_BUILD_VERSION=1 -f ./Makefile
make[4]: *** Nessuna regola per generare l'obiettivo «debian/canonical-certs.pem», necessario per «certs/x509_certificate_list». Arresto.
make[4]: *** Attesa per i processi non terminati....
make[3]: *** [Makefile:1729: certs] Errore 2
make[3]: *** Attesa per i processi non terminati....
arch/x86/hyperv/hv_apic.c: In function ‘__send_ipi_one’:
arch/x86/hyperv/hv_apic.c:201:1: warning: the frame size of 1032 bytes is larger than 1024 bytes [-Wframe-larger-than=]
201 | }
arch/x86/hyperv/hv_apic.c: In function ‘hv_send_ipi_mask_allbutself’:
arch/x86/hyperv/hv_apic.c:226:1: warning: the frame size of 1032 bytes is larger than 1024 bytes [-Wframe-larger-than=]
226 | }
arch/x86/kernel/cpu/mce/core.o: warning: objtool: mce_panic()+0x123: unreachable instruction
kernel/exit.o: warning: objtool: __x64_sys_exit_group()+0x18: unreachable instruction
fs/btrfs/extent_io.o: warning: objtool: __set_extent_bit.cold()+0xc: unreachable instruction
fs/btrfs/relocation.o: warning: objtool: update_backref_node.cold()+0xb: unreachable instruction
arch/x86/xen/enlighten_pv.o: warning: objtool: xen_cpuid()+0x20: can't find jump dest instruction at .text+0x97
arch/x86/kernel/smpboot.o: warning: objtool: native_play_dead()+0x131: unreachable instruction
arch/x86/kernel/kvm.c: In function ‘kvm_send_ipi_mask_allbutself’:
arch/x86/kernel/kvm.c:503:1: warning: the frame size of 1032 bytes is larger than 1024 bytes [-Wframe-larger-than=]
503 | }
fs/jffs2/xattr.c: In function ‘jffs2_build_xattr_subsystem’:
fs/jffs2/xattr.c:887:1: warning: the frame size of 1128 bytes is larger than 1024 bytes [-Wframe-larger-than=]
887 | }
