I have 22.10 running on a Dell laptop, received a popup to upgrade to 23.04. During the installation I got an error message stating that the installation of linux-headers-6.2.0-20-generic has failed due to an error. At the end it said that the system will be left in an unstable state. I have not restarted the laptop, but I believe it wont restart if I tried! :/
Here is the output of sudo dpkg --configure -a:
Setting up linux-image-6.2.0-20-generic (6.2.0-20.20) ...
Setting up linux-headers-6.2.0-20-generic (6.2.0-20.20) ...
/etc/kernel/header_postinst.d/dkms:
* dkms: running auto installation service for kernel 6.2.0-20-generic
Sign command: /usr/bin/kmodsign
Signing key: /var/lib/shim-signed/mok/MOK.priv
Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module:
Cleaning build area...
make -j4 KERNELRELEASE=6.2.0-20-generic all INCLUDEDIR=/lib/modules/6.2.0-20-generic/build/include KVERSION=6.2.0-20-generic DKMS_BUILD=1...(bad exit status: 2)
ERROR (dkms apport): binary package for evdi: 1.12.0 not found
Error! Bad return status for module build on kernel: 6.2.0-20-generic (x86_64)
Consult /var/lib/dkms/evdi/1.12.0/build/make.log for more information.
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
dpkg: error processing package linux-headers-6.2.0-20-generic (--configure):
installed linux-headers-6.2.0-20-generic package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-generic:
linux-headers-generic depends on linux-headers-6.2.0-20-generic; however:
Package linux-headers-6.2.0-20-generic is not configured yet.
dpkg: error processing package linux-headers-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-headers-generic (= 6.2.0.20.20); however:
Package linux-headers-generic is not configured yet.
dpkg: error processing package linux-generic (--configure):
Processing triggers for linux-image-6.2.0-20-generic (6.2.0-20.20) ...
/etc/kernel/postinst.d/dkms:
- dkms: running auto installation service for kernel 6.2.0-20-generic
Building module:
...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-6.2.0-20-generic (--configure):
installed linux-image-6.2.0-20-generic package post-installation script subprocess returned error exit status 1
linux-generic
What should I do to fix this?
