When I try to update to the latest version of the kernel in Ubuntu 24.04, it gives me the following error. It seems to be a problem with my ethernet driver preventing a full update?
I have tried fixing broken packages but it does not work. Any advice would be greatly appreciated.
The error I am getting is:
Reading package lists... Done
Building dependency tree... Done
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-headers-6.11.0-21-generic (6.11.0-21.21~24.04.1) ...
/etc/kernel/header_postinst.d/dkms:
 * dkms: running auto installation service for kernel 6.11.0-21-generic
Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf
Deprecated feature: REMAKE_INITRD (/etc/dkms/framework.conf)
Sign command: /usr/bin/kmodsign
Signing key: /var/lib/shim-signed/mok/MOK.priv
Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module: Cleaning build area... 'make' -j16 KVER=6.11.0-21-generic BSRC=/lib/modules/6.11.0-21-generic modules.. ..(bad exit status: 2) ERROR (dkms apport): binary package for r8125: 9.013.02 not found Error! Bad return status for module build on kernel: 6.11.0-21-generic (x86_64) Consult /var/lib/dkms/r8125/9.013.02/build/make.log for more information. dkms autoinstall on 6.11.0-21-generic/x86_64 succeeded for realtek-r8125 dkms autoinstall on 6.11.0-21-generic/x86_64 failed for r8125(10) Error! One or more modules failed to install during autoinstall. Refer to previous errors for more information.
  • dkms: autoinstall for kernel 6.11.0-21-generic ...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11 dpkg: error processing package linux-headers-6.11.0-21-generic (--configure): installed linux-headers-6.11.0-21-generic package post-installation script subp rocess returned error exit status 11 Setting up linux-image-6.11.0-21-generic (6.11.0-21.21~24.04.1+1) ... dpkg: dependency problems prevent configuration of linux-headers-generic-hwe-24. 04: linux-headers-generic-hwe-24.04 depends on linux-headers-6.11.0-21-generic; how ever: Package linux-headers-6.11.0-21-generic is not configured yet.
dpkg: error processing package linux-headers-generic-hwe-24.04 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of linux-generic-hwe-24.04: linux-generic-hwe-24.04 depends on linux-headers-generic-hwe-24.04 (= 6.11.0-21 .21~24.04.1); however: Package linux-headers-generic-hwe-24.04 is not configured yet.
dpkg: error processing package linux-generic-hwe-24.04 (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup erro r from a previous failure. No apport report written because the error message ind icates its a followup error from a previous failure. Processing triggers for linu x-image-6.11.0-21-generic (6.11.0-21.21~24.04.1+1) ... /etc/kernel/postinst.d/dkms:
  • dkms: running auto installation service for kernel 6.11.0-21-generic
Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf ) Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf ) Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf ) Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf ) Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf ) Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf ) Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf ) Deprecated feature: REMAKE_INITRD (/etc/dkms/framework.conf) Sign command: /usr/bin/kmodsign Signing key: /var/lib/shim-signed/mok/MOK.priv Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der Deprecated feature: REMAKE_INITRD (/var/lib/dkms/r8125/9.013.02/source/dkms.conf )
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11 dpkg: error processing package linux-image-6.11.0-21-generic (--configure): installed linux-image-6.11.0-21-generic package post-installation script subpro cess returned error exit status 11 No apport report written because MaxReports is reached already Errors were encoun tered while processing: linux-headers-6.11.0-21-generic linux-headers-generic-hwe-24.04 linux-generic-hwe-24.04 linux-image-6.11.0-21-generic E: Sub-process /usr/bin/dpkg returned an error code (1)
NotTheDr01ds
  • 22,082
