I've sunk about 4 hours so far on this and tried all the common solution that have worked for others. I first lost my sound on upgrade to 22.04 and it's still not come back after upgrading to 22.10.
Below what I've tried and output of various diagnostic commands I've seen.
Please help!
Things tried:
Have tried the following (in some cases multiple times)
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
sudo apt autoremove
sudo apt install update-manager-core
sudo do-release-upgrade
sudo touch /usr/share/pipewire/media-session.d/with-pulseaudio
systemctl --user restart pipewire-session-manager
sudo alsa force-reload
pulseaudio --kill
pulseaudio --start
sudo ln -s /usr/share/pipewire /etc/pipewire
systemctl --user start pulseaudio
sudo apt install libldacbt-{abr,enc}2
sudo apt install libspa-0.2-bluetooth pipewire-audio-client-libraries pipewire-media-session
options tried in /etc/modprobe.d/alsa-base.conf
options snd-hda-intel dmic_detect=0
and also:
options snd-hda-intel model=generic
sudo vim /etc/default/grub
changed: GRUB_CMDLINE_LINUX="" To: GRUB_CMDLINE_LINUX="intel_iommu=on,igfx_off"
then, of course:
sudo update-grub
reboot
Diagnostic commands:
erich@erich-nuc:~$ pactl info | grep '^Server Name'
Server Name: PulseAudio (on PipeWire 0.3.58)
erich@erich-nuc:~$ cat /proc/asound/modules
0 snd_hda_intel
1 snd_usb_audio
erich@erich-nuc:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
## erich@erich-nuc:~$ lspci -v | grep -A7 -i "audio"
00:1f.3 Audio device: Intel Corporation Cannon Point-LP High Definition Audio Controller (rev 30)
Subsystem: Intel Corporation Cannon Point-LP High Definition Audio Controller
Flags: bus master, fast devsel, latency 32, IRQ 134
Memory at b0530000 (64-bit, non-prefetchable) [size=16K]
Memory at b0200000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci_intel_cnl
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
Subsystem: Intel Corporation Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
Flags: bus master, fast devsel, latency 0, IRQ 135
Memory at b0460000 (64-bit, non-prefetchable) [size=16K]
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
erich@erich-nuc:~$ inxi -A
Audio:
Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
Device-3: Z-Star Micro Venus USB2.0 Camera type: USB
driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.19.0-38-generic running: yes
Sound Server-2: PipeWire v: 0.3.58 running: yes
erich@erich-nuc:~$ sudo lspci -v
00:00.0 Host bridge: Intel Corporation Coffee Lake HOST and DRAM Controller (rev 0b)
Subsystem: Intel Corporation Coffee Lake HOST and DRAM Controller
Capabilities: [e0] Vendor Specific Information: Len=10 <?>
Kernel driver in use: skl_uncore
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Subsystem: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Flags: fast devsel, IRQ 255
Memory at b0545000 (64-bit, non-prefetchable) [disabled] [size=4K]
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [dc] Power Management version 2
Capabilities: [f0] PCI Advanced Features
00:12.0 Signal processing controller: Intel Corporation Cannon Point-LP Thermal Controller (rev 30)
Subsystem: Intel Corporation Cannon Point-LP Thermal Controller
Flags: fast devsel, IRQ 16
Memory at b0544000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 3
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Point-LP USB 3.1 xHCI Controller (rev 30) (prog-if 30 [XHCI])
Subsystem: Intel Corporation Cannon Point-LP USB 3.1 xHCI Controller
Flags: bus master, medium devsel, latency 0, IRQ 124
Memory at b0520000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Capabilities: [90] Vendor Specific Information: Len=14 <?>
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Point-LP Shared SRAM (rev 30)
Subsystem: Intel Corporation Cannon Point-LP Shared SRAM
Flags: fast devsel
Memory at b053a000 (64-bit, non-prefetchable) [disabled] [size=8K]
Memory at b0543000 (64-bit, non-prefetchable) [disabled] [size=4K]
Capabilities: [80] Power Management version 3
00:14.3 Network controller: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] (rev 30)
DeviceName: WIFI
Subsystem: Intel Corporation Cannon Point-LP CNVi [Wireless-AC]
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at b0534000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] Null
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:15.0 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Controller #0 (rev 30)
Subsystem: Intel Corporation Cannon Point-LP Serial IO I2C Controller
Memory at b053d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Controller #1 (rev 30)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at b0541000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller: Intel Corporation Cannon Point-LP MEI Controller #1 (rev 30)
Subsystem: Intel Corporation Cannon Point-LP MEI Controller
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at b0540000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [a4] Vendor Specific Information: Len=14 <?>
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 30)
Subsystem: Intel Corporation 82801 Mobile SATA Controller [RAID mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 16
Memory at b0538000 (32-bit, non-prefetchable) [size=8K]
Memory at b053f000 (32-bit, non-prefetchable) [size=256]
I/O ports at 4050 [size=8]
I/O ports at 4040 [size=4]
I/O ports at 4020 [size=32]
Memory at b053e000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [d0] MSI-X: Enable+ Count=1 Masked-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Kernel driver in use: ahci
Kernel modules: ahci
00:19.0 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Host Controller (rev 30)
Subsystem: Intel Corporation Cannon Point-LP Serial IO I2C Host Controller
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at b0542000 (64-bit, non-prefetchable) [size=4K]
00:1c.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #5 (rev f0) (prog-if 00 [Normal decode])
Subsystem: Intel Corporation Cannon Point-LP PCI Express Root Port
Flags: bus master, fast devsel, latency 0, IRQ 121
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 3000-3fff [size=4K] [16-bit]
Memory behind bridge: b0400000-b04fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: a0000000-b01fffff [size=258M] [32-bit]
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Intel Corporation Cannon Point-LP PCI Express Root Port
Capabilities: [a0] Power Management version 3
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Access Control Services
Capabilities: [150] Precision Time Measurement
Capabilities: [220] Secondary PCI Express
Capabilities: [250] Downstream Port Containment
Kernel driver in use: pcieport
00:1d.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #15 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: b0300000-b03fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Capabilities: [200] L1 PM Substates
00:1f.0 ISA bridge: Intel Corporation Cannon Point-LP LPC Controller (rev 30)
Subsystem: Intel Corporation Cannon Point-LP LPC Controller
Capabilities: [80] Vendor Specific Information: Len=14 <?>
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
00:1f.4 SMBus: Intel Corporation Cannon Point-LP SMBus Controller (rev 30)
Subsystem: Intel Corporation Cannon Point-LP SMBus Controller
Flags: medium devsel, IRQ 16
Memory at b053c000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Cannon Point-LP SPI Controller (rev 30)
Subsystem: Intel Corporation Cannon Point-LP SPI Controller
Flags: fast devsel
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (6) I219-V (rev 30)
DeviceName: LAN
Subsystem: Intel Corporation Ethernet Connection (6) I219-V
Flags: bus master, fast devsel, latency 0, IRQ 125
Memory at b0500000 (32-bit, non-prefetchable) [size=128K]
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa [Radeon 540X/550X/630 / RX 640 / E9171 MCM] (rev c3) (prog-if 00 [VGA controller])
Subsystem: Intel Corporation Lexa [Radeon 540X/550X/630 / RX 640 / E9171 MCM]
Flags: bus master, fast devsel, latency 0, IRQ 136
Memory at a0000000 (64-bit, prefetchable) [size=256M]
Memory at b0000000 (64-bit, prefetchable) [size=2M]
I/O ports at 3000 [size=256]
Memory at b0400000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at b0440000 [disabled] [size=128K]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [150] Advanced Error Reporting
Capabilities: [200] Physical Resizable BAR
Capabilities: [270] Secondary PCI Express
Capabilities: [2b0] Address Translation Service (ATS)
Capabilities: [2c0] Page Request Interface (PRI)
Capabilities: [2d0] Process Address Space ID (PASID)
Capabilities: [320] Latency Tolerance Reporting
Capabilities: [328] Alternative Routing-ID Interpretation (ARI)
Capabilities: [370] L1 PM Substates
Kernel driver in use: amdgpu
Kernel modules: amdgpu
Subsystem: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader
Flags: bus master, fast devsel, latency 0, IRQ 123
Memory at b0300000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 00-00-00-01-00-4c-e0-00
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
erich@erich-nuc:~$ uname -r
5.19.0-38-generic
