Just did a fresh install of Ubuntu 22.10 on my Asus Zenbook 14 OLED (model Q409ZA) but I have no audio. I followed a guide on installing pipewire, but that did not work. I saw some other questions that were related as well but didn't find any solutions. I do see in the settings that the bar is moving when I have audio playing. When I try to do the test audio, nothing is played there either. Attached is a screenshot of the PulseAudio Volume Control output devices. In windows the device is listed as Realtek, so I don't know if there is some kind of driver issue.
Edit:
I did have to reinstall Ubuntu but after the reinstall I did have the same thing - no audio. Followed another guide Fix No Sound Issue but the only thing I found a bit weird was my output of pacmd list-sink-inputs was 0 sink input(s) available. even though I had audio going through VLC and Firefox. I tried doing what one of the answers said, which was to do the inxi -xxz --audio which showed that pulseaudio was not running. So I did the commands systemctl --user enable pulseaudio and systemctl --user start pulseaudio which then failed, so I restarted, then started pulseaudio, which did start, but still got no audio, checking the status of pulseaudio again I got the following:
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; preset: enabled)
Active: active (running) since Wed 2023-04-05 14:35:43 CDT; 1min 19s ago
TriggeredBy: ● pulseaudio.socket
Main PID: 3144 (pulseaudio)
Tasks: 8 (limit: 8993)
Memory: 6.7M
CPU: 501ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
└─3144 /usr/bin/pulseaudio --daemonize=no --log-target=journal
Apr 05 14:36:52 ZLaptop pulseaudio[3144]: Failed to create sink input: sink is suspended.
Apr 05 14:36:57 ZLaptop pulseaudio[3144]: Failed to create sink input: sink is suspended.
