This appears to be a known issue. Read more on snapcraft forums.
I've tried to install Krita using the command snap install krita, as I get the following error:
error: cannot perform the following tasks:
Ensure prerequisites for "krita" are available (cannot install prerequisite "kde-frameworks-5-96-qt-5-15-5-core20": no snap revision available as specified)
I've tried to look up this kde-frameworks snap, but the message I got back is:
error: no snap found for "kde-frameworks-5-96-qt-5-15-5-core20"
It also doesn't show up in the snap store software on my desktop, but I can find it online on snapcraft.io at https://snapcraft.io/kde-frameworks-5-96-qt-5-15-5-core20
When I try to open up the snap store from the website using the direct install link, I get the error message
failed to install: not supported
in the desktop application. When I try to use the code sudo snap install kde-frameworks-5-96-qt-5-15-5-core20, the message is
   error: snap "kde-frameworks-5-96-qt-5-15-5-core20" is not available on stable but is available to
   install on the following channels:
candidate snap install --candidate kde-frameworks-5-96-qt-5-15-5-core20 beta snap install --beta kde-frameworks-5-96-qt-5-15-5-core20 edge snap install --edge kde-frameworks-5-96-qt-5-15-5-core20
Please be mindful pre-release channels may include features not completely tested or implemented. Get more information with 'snap info kde-frameworks-5-96-qt-5-15-5-core20'.
However, none of the three code works, they all return similar messages as above.
I've found many other versions of kde-frameworks, with similar naming structures as this one on the snap store app, but installing one (I went with kde-frameworks-5-102-qt-5-15-8-core22 as it seemed to be a newer version going by the name) didn't make any difference.
What am I missing, why doesn't it work?
Nmath
  • 12,664
gerath
  • 41
