Hi I am looking for some kind of script/software that can help me to send SMS from my Ubuntu machine . A desktop client/application actually by using web services which we use to send sms like way2sms.com or 160by2.com etc.
Asked
Active
Viewed 8,816 times
Here you go. Create an account at 160by2.com and install php on your system.
sudo apt-get install php5-cli php5-curl curl
Paste your number and password where i've mentioned and run this script:
<?php
echo"Phone: ";$phno=trim(fgets(STDIN));
echo"Message: ";$msg=trim(fgets(STDIN));
echo"Message Length: ".strlen($msg)."\nSending...";
$yournumber=''; //your number inside the single quotes
$yourpassword='';//your password inside the single quotes
$cur=curl_init("http://160by2.com/re-login");
curl_setopt($cur,CURLOPT_POST,1);
curl_setopt($cur,CURLOPT_POSTFIELDS,"username=$yournumber&password=$yourpassword");
curl_setopt($cur,CURLOPT_COOKIESESSION,1);
curl_setopt($cur,CURLOPT_COOKIEJAR,"cookie");
curl_exec($cur);
curl_close($cur);
$cur=curl_init("http://160by2.com/SendSMSAction");
curl_setopt($cur,CURLOPT_AUTOREFERER,1);
curl_setopt($cur,CURLOPT_COOKIEFILE,"cookie");
curl_setopt($cur,CURLOPT_POSTFIELDS,"mobile1=$phno&msg1=$msg&action1=sa65sdf656fdfd");
$x=curl_exec($cur);
curl_close($cur);
echo"\nSent!";
Save the script as sms.php.Then on terminal run php sms.php
DONE!
It's simple.
Just go register at CS Networks and you may send messages from terminal with the following command:
wget http://api.cs-networks.net:9011/bin/send?USERNAME=yourusername&PASSWORD=yourpassword&DESTADDR=447123456789&MESSAGE=somemessageSOURCEADDR=test
Smith
- 31
-1
Here is a link for downloading .deb files for both 32-bit and 64-bit versions of sendsms / gsendsms. Sendsms is open source software published under a GNU/GPL license.
https://www.cs-networks.net/index.php/products/toolsandutils/linux-sendsms
It will allow you to send messages from the terminal / or simple GUI under GNOME.
