I tried the solution here to remap Caps Lock to Control.
Open the following for editing:
sudo vi /etc/default/keyboard
And edit XKBOPTIONS="ctrl:swapcaps"
Then, reconfigure:
sudo dpkg-reconfigure keyboard-configuration
I started with exactly that not to get too crazy. It worked. But now I can't get it to go back.
I edited the keyboard file back to its original contents...
# KEYBOARD CONFIGURATION FILE
Consult the keyboard(5) manual page.
XKBMODEL="pc105" XKBLAYOUT="us" XKBVARIANT="" XKBOPTIONS=""
BACKSPACE="guess"
... but even after rebooting, caps is still control and control is still caps.
Where should I look to set things back?
What should I do to get both Control and Caps to invoke Control?
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.2 LTS
Release:    22.04
Codename:   jammy
ruffin
  • 111
  • Install the gnome-tweaks package, if it's not already installed.
  • Open Tweaks -> Keyboard & Mouse -> Additional Layout Options -> Ctrl position
  • Uncheck the "Swap Ctrl and Caps Lock" option.
  • Check the "Caps Lock as Ctrl" option.
You can use the remapper deamon keyd for this purpose. See this answer for installation, usage and tips.
After installation, use the config below.
[ids]
[main]
capslock = layer(control)
Rasmus
  • 8,655
