I am using Ubuntu MATE 22.04. Towards night, redshift sets a color temperature of 4500K.
How to reduce the color temperature even further? Unlike the Night Light feature in GNOME/KDE, Redshift does not have any simple method to manually change the color temperature (but it might be configurable by editing redshift.conf, which is why I am asking this question).
To expand (or to provide some contrast compared to the answer found in the duplicate post). Here's what I have in my ~/.config/redshift.conf file:
; Global settings for redshift
[redshift]
; Set the day and night screen temperatures
temp-day=3400
temp-night=3400
; Enable/Disable a smooth transition between day and night ; 0 will cause a direct change from day to night screen temperature. ; 1 will gradually increase or decrease the screen temperature. transition=1
; Set the screen brightness. Default is 1.0. ;brightness=0.9 ; It is also possible to use different settings for day and night ; since version 1.8. ;brightness-day=0.7 ;brightness-night=0.4 ; Set the screen gamma (for all colors, or each color channel ; individually) ;gamma=0.8 ;gamma=0.8:0.7:0.8 ; This can also be set individually for day and night since ; version 1.10. ;gamma-day=0.8:0.7:0.8 ;gamma-night=0.6
; Set the location-provider: 'geoclue', 'geoclue2', 'manual' ; type 'redshift -l list' to see possible values. ; The location provider settings are in a different section. location-provider=manual
; Set the adjustment-method: 'randr', 'vidmode' ; type 'redshift -m list' to see all possible values. ; 'randr' is the preferred method, 'vidmode' is an older API. ; but works in some cases when 'randr' does not. ; The adjustment method settings are in a different section. ;adjustment-method=randr
; Configuration of the location-provider: ; type 'redshift -l PROVIDER:help' to see the settings. ; ex: 'redshift -l manual:help' ; Keep in mind that longitudes west of Greenwich (e.g. the Americas) ; are negative numbers. [manual] lat=48.1 lon=11.6
; Configuration of the adjustment-method ; type 'redshift -m METHOD:help' to see the settings. ; ex: 'redshift -m randr:help' ; In this example, randr is configured to adjust screen 1. ; Note that the numbering starts from 0, so this is actually the ; second screen. If this option is not specified, Redshift will try ; to adjust all screens. ; [randr] ; screen=1
I have everything commented out except for:
[redshift]
temp-day=3400
temp-night=3400
transition=1
[manual]
lat=48.1
lon=11.6
I have both temp-day and temp-night set to 3400. You can adjust these accordingly.
transition=1 is probably not necessary for me because I have day and night set to the same value but this may be of interest to you.
location-provider=manual is kind of important as the automatic methods usually fail and redshift will fail to start.
  • If you have night and day set to different temperatures, you should determine your latitude (lat) and longitude (lon) and set these accordingly.
  • Of course: if day and night are set to the same temperature, you can leave these at the default coordinates (41.8 and 11.6).
mchid
  • 44,904
  • 102
  • 162
