Background: I am running Ubuntu 22.04.1 LTS. I am new to Linux. I do not have a programming or computer science background.
Problem: I am trying to reassign the function of 'Tab' to the 'Insert' key as the main 'Tab' key is broken.
Solutions tried: I went through the following steps:
  1. Found out the keycode for the 'Insert' key using xmodmap -pke command.
  2. Used the command xmodmap -e "keycode 118 = Tab" command to assign the key to tab.
  3. running xmodmap -pke command again shows that keycode 118 has been assigned to 'Tab' key.
  4. However, when pressed, 'Insert' key does not act as 'tab' key.
I am at a loss. What went wrong? Thanks in advance.
PGN
You can use the remapper deamon keyd for this purpose. See this answer for installation, usage and tips.
After installation, use the config below:
[ids]
[main]
Make Insert key execute Tab function:
insert = tab
Rasmus
  • 8,655
