I often need to move my laptop from one working place to another. When I do this, there are two events Ubuntu responds to by changing the monitor set up:
  • Removing/attaching the VGA cable
  • Closing/opening the lid of the laptop
While removing the VGA cable gives me what I need (single screen, highest native resolution on the external screen if connected; otherwise highest resolution on the laptop), the laptop close/open lid response is not as good.
Every time I close or open the lid, Ubuntu reconfigures the monitor set up. When I close the lid now... the screen goes black for a few seconds and it switches to clone, with my laptop screen disabled. Reopening results in... briefly a black screen, then the external monitor being used as desktop extension.
Update: Things changed a bit recently, the behaviour is more predictable now. Closing the lid switches to single display, opening to dual screen (not clone). My question is still accurate: see below.
Ubuntu thinks too much. My first and foremost question: Is there any way to let Ubuntu ignore lid close events?
Ideally (or when there's no way to solve above question) I'd want to change how it deals with the screen reconfiguration. Why does Ubuntu toggle the screen configuration between external, clone and single display? Can't I just configure it to always use the external monitor, when present, in single screen mode?
Note that similar questions have been asked before (most notably this one), but these have been closed perhaps wrongly.
Any ideas are very welcome, I don't mind playing around a bit to see if something works.
Tomas
  • 1,099
Lid events are triggered by the lidbtn file in /etc/acpi/events/, which contains two active lines:
event=button[ /]lid
action=/etc/acpi/lid.sh -- comment this out with a # at the beginning
You can ignore lid open/close events by commenting out the second line with a # and then rebooting.
You can look at and try to modify the file /etc/acpi/lid.sh and the functions/commands it references.
BUT (BIG CAVEAT): If your laptop BIOS uses the lid close/open to switch the internal/external video out ports on/off, then this is beyond the OS ACPI event handler's powers.
ish
  • 141,990
This behavior is a Gnome feature, and it is controlled by a dconf setting. You can change it via dconf-editor or directly using command line:
gsettings set org.gnome.settings-daemon.plugins.xrandr default-monitors-setup <value>
The description says following:
Summary: Whether to turn off specific monitors after boot
'clone' will display the same thing on all monitors, 'dock' will switch off the internal monitor, 'do-nothing' will use the default Xorg behaviour (extend the desktop in recent versions). The default, 'follow-lid', will choose between 'do-nothing' and 'dock' depending on whether the lid is (respectively) open or closed.
So, if you'd like to use only the external monitor when it is connected, use dock as <value>.
If you want both monitors to always work, no matter if lid is closed or not, use do-nothing. (I often closed the lid temporarily just so that it did not shine into my dark room, I didn't want all windows to migrate to external monitor.)
And finally, if you want to use laptop screen but only when it is open, use follow-lid. (Use case: amount of free space on your desk varies, and sometimes you have to put the laptop behind your monitor instead of beside it.)
EvgEnZh
  • 755
I can answer this part. I run ubuntu 17.10 on wayland. In the gnome-control-center -> device -> display, you can choose single display with only the $external_monitor enabled, then click on "apply". That generates a $HOME/.confg/monitors.xml file. The file fixes the display arragemment when the same $external_monitor is connected, and toggles on the internal monitor once it's disconnected. What's better, you can put the same monitors.xml in /var/lib/gdm3/.config/, in that case the same thing holds for GDM too.
funicorn
  • 4,306
  • 17
