What I would like to do is, instead of pressing Shift+1 or Shift+2 to see ! or @ respectively, have by default ! @ # $ % ^ & * ( ) instead of 1 2 3 4 5 6 7 8 9 0, and maybe if I have my NumLock off it could be 1 2 3 4 5 6 7 8 9 0. But if NumLock is off I would have ! @ # $ % ^ & * ( ) in the first row, and could have access to the numbers if I use the Shift key.
Can someone get me to the right track?
// Begin: Insert 42lx by cosvaldo@42lx.com
// This file is called 42lx and must be placed into the following linux folder:
// /usr/share/X11/xkb/symbols
partial alphanumeric_keys
xkb_symbols "basic" {
name[Group1]= "US/ASCII";
key <AE01> { [ 1, exclam, exclamdown, onesuperior ] };
key <AE02> { [ 2, at, twosuperior, dead_doubleacute ] };
key <AE03> { [ 3, numbersign, threesuperior, dead_macron ] };
key <AE04> { [ 4, dollar, currency, sterling ] };
key <AE05> { [ 5, percent, EuroSign, dead_cedilla ] };
key <AE06> { [ 6, dead_circumflex, onequarter, asciicircum ] };
key <AE07> { [ 7, ampersand, onehalf, dead_horn ] };
key <AE08> { [ 8, asterisk, threequarters, dead_ogonek ] };
key <AE09> { [ 9, parenleft, leftsinglequotemark, dead_breve ] };
key <AE10> { [ 0, parenright, rightsinglequotemark, dead_abovering ] };
modifier_map Shift { Num_Lock };
//modifier_map Shift { Shift_L, Shift_R };
//modifier_map Mod2 { Num_Lock };
// key <NMLK> { [ Num_Lock ] };
// End: Insert 42lx by cosvaldo@42lx.com
I also will insert this code:
// /usr/share/X11/xkb/rules/evdev.xml
// It will be inserted at line ... this code in evdev.xml:
<!-- Begin: Insert 42lx by cosvaldo@42lx.com -->
<layout>
<configItem>
<name>42lx</name>
<shortDescription>42lx.com</shortDescription>
<description>42lx English (US): switch between numbers and signs at the
first line, below function keys with Num Lock, Left and Right
Shift.</description>
<languageList>
<iso639Id>eng</iso639Id>
<iso639Id>por</iso639Id>
</languageList>
</configItem>
<variantList/>
</layout>
<!-- End: Insert 42lx by cosvaldo@42lx.com -->
I already saw this link and this one, but something is missing here.
