dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem
Here is some of the processes I tried:
robterri@system76-pc:~$ sudo apt upgrade
[sudo] password for robterri:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem. robterri@system76-pc:~$ sudo apt-get install -f
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem. robterri@system76-pc:~$ s aux | grep -i apt s: command not found robterri@system76-pc:~$ s aux | grep -i apt s: command not found robterri@system76-pc:~$ udo dpkg --configure -a Command 'udo' not found, but can be installed with: sudo apt install udo
robterri@system76-pc:~$ sudo apt install udo E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
robterri@system76-pc:~$ ps aux | grep -i apt root 1062 0.0 0.0 137172 10068 ? Ssl 19:48 0:00 /usr/sbin/thermald --systemd --dbus-enable --adaptive robterri 19313 0.0 0.0 17864 2376 pts/0 S+ 21:00 0:00 grep --color=auto -i apt
robterri@system76-pc:~$ sudo kill -9 19313 kill: (19313): No such process robterri@system76-pc:~$
Used these websites for guide: E: dpkg was interrupted... run 'sudo dpkg --configure -a'
Error: "dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem"
apt-get -f install
y
sudo apt update sudo apt upgrade
Goes to a screen that states package configuration Configuring ttf-mscorefonts-installer TrueType core fonts for the Web EULA
I think what locked it up was "sudo apt install ubuntu-restricted-extras Install Multimedia codecs. Was trying to do "25 things you must do after installing Ubuntu 22.04 LTS (right now) on YouTube.
Had killed 3 other processes before I started keeping track. Process 14272, 15502, 19313.
Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 20726 (apt)
Tried to upgrade again goes on & on to 150s never stops.
SOLVED
Archisman & Ubuntu commuity: Thanks for being patient.
I could not figure out how to activate the "OK" button on the package configuration Configuring ttf-mscorefonts-installer TrueType core fonts for the Web EULA. The answer and links at the top help solve the problem.
Apologize for not providing OS and details of computer. Lack of sleep did not help.
Thanks again!
Pilot6
  • 92,041
Reboot your computer. It will remove the lock file.
Then run the command sudo dpkg --configure -a (you were previously missing the "s" in sudo, which is why the computer said that "udo" not found).
You will have to accept the EULA using your keyboard in order to install this software.
