I'm trying to create these shortcuts:
  • Remap ctrl+c,v,x to ctrl+j,k,q because I'm using Dvorak layout.
  • alt+i,j,k,l to arrow keys. And it must work with the other modifiers, like shift+alt+l -> shift+right.
I used to have this on Windows, configured with a really great app AutoHotKey. But on Linux, surprisingly, there are no such straightforward options.
What doesn't work:
  • Regular settings. I can't even change copy-paste there, and even if I could, there would be another problem (happened on MacOS): Basically, I need to silence ctrl+j and emit ctrl+c, not just do copy when I press ctrl+j. This is because other apps don't expect such weird combinations and can have some other functionality assigned to it that would conflict.
  • Third party apps:
    • AutoKey: It doesn't silence the shortcuts used to execute scripts. So if I write a script to emit Up when I press alt+i, the system will see alt+i+Up.
    • Ktrl: It was working (with two very annoying bugs), but I just got a new laptop and installed newer version of Ubuntu, and it doesn't work here now. Plus I really don't want to deal with those bugs anymore.
    • I have looked into other apps and couldn't find anything else
You can use the remapper deamon keyd for this purpose. See this answer for installation, usage and tips.
After installation, use the config below. It makes left Control activate a layer, customcontrol, while held, where every thing you press is be default modified by Control (the :C), except for the keys remapped in the layer---in this case x, c and v which are remapped to Control + q etc. Same-same for left Alt.
[ids]
[main]
leftcontrol = layer(customcontrol) leftalt = layer(customalt)
[customcontrol:C]
x = C-q c = C-j v = C-k
[customalt:A] i = up k = down j = left l = right
Rasmus
  • 8,655
