331
I would like to determine the location of a file using command-line. I have tried:
find . -type f -name "postgis-2.0.0"
and
locate postgis-2.0.0
to no avail. What is the command to determine the file's directory, provided its name?
Sam007
  • 4,653
9 Answers9
413
Try find ~/ -type f -name "postgis-2.0.0" instead.
Using . will only search the current directory. ~/ will search your entire home directory (likely where you downloaded it to). If you used wget as root, its possible it could be somewhere else so you could use / to search the whole filesystem.
Goodluck
adempewolff
  • 12,400
45
I would try:
sudo find / -type d -name "postgis-2.0.0"
The . means search only in the current directory, it is best to search everything from root if you really don't know. Also, type -f means search for files, not folders. Adding sudo allows it to search in all folders/subfolders.
Your syntax for locate is correct, but you may have to run
sudo updatedb
first. For whatever reason, I never have good luck with locate though.
locate uses database of files and directories made by updatedb. So if you have downloaded a new file there is more chance that your updatedb has not updated the database of files and directories. You can use sudo updatedb before using locate utility program. updatedb generally runs once a day by itself on linux systems.
reverendj1
  • 16,403
30
The other answers are good, but I find omitting Permission denied statements gives me clearer answers (omits stderrs due to not running sudo):
find / -type f -iname "*postgis-2.0.0*" 2>/dev/null
where:
  • / can be replaced with the directory you want to start your search from
  • f can be replaced with d if you're searching for a directory instead of a file
  • -iname can be replaced with -name if you want the search to be case sensitive
  • the *s in the search term can be omitted if you don't want the wildcards in the search
An alternative is:
find / -type f 2>/dev/null | grep "postgis-2.0.0"
This way returns results if the search-term matches anywhere in the complete file path, e.g. /home/postgis-2.0.0/docs/Readme.txt
muru
  • 207,228
zanbri
  • 401
16
Try find . -name "*file_name*"
  • where you can change '.'(look into the Current Directory) to '/'(look into the entire system) or '~/'(look into the Home Directory).
  • where you can change "-name" to "-iname" if you want no case sensitive.
  • where you can change "file_name"(a file that can start and end with whatever it is) to the exactly name of the file.
RuiVBoas
  • 261
15
find is one of the most useful Linux/Unix tools.
Try find . -type d | grep DIRNAME
Mitch
  • 109,787
This should simplify the locating of file:
This would give you the full path to the file
tree -f  / | grep postgis-2.0.0
Tree lists the contents of directories in a tree-like format. the -f tells tree to give the full path to the file. since we have no idea of its location or parent location, good to search from the filesystem root / recursively downwards. We then send the output to grep to highlight our word, postgis-2.0.0
muru
  • 207,228
ptetteh227
  • 2,044
$ find . -type f | grep IMG_20171225_*
Gives
./03-05--2018/IMG_20171225_200513.jpg
The DOT after the command find is to state a starting point,
Hence - the current folder,
"piped" (=filtered) through the name filter IMG_20171225_*
Jadeye
  • 2,342
Try find -iname filename.txt command.
This command searches for and displays the paths of all files that exist in the system.
While find command is simplest way to recursively traverse the directory tree, there are other ways and in particular the two scripting languages that come with Ubuntu by default already have the ability to do so.
bash
bash has a very nice globstar shell option, which allows for recursive traversal of the directory tree. All we need to do is test for whether item in the ./**/* expansion is a file and whether it contains the desired text:
bash-4.3$ for f in ./**/* ;do [ -f "$f" ] && [[ "$f" =~ "postgis-2.0.0" ]] && echo "$f"; done
./testdir/texts/postgis-2.0.0
Perl
Perl has Find module, which allows to perform recursive traversal of directory tree, and via subroutine perform specific action on them. With a small script, you can traverse directory tree, push files that contain the desired string into array, and then print it like so:
#!/usr/bin/env perl
use strict;
use warnings;
use File::Find;
my @wanted_files;
find(
     sub{
         -f $_ && $_ =~ $ARGV[0]
               && push @wanted_files,$File::Find::name
foreach(@wanted_files){
    print "$_\n"
And how it works:
$ ./find_file.pl  "postgis-2.0.0"
Python
Python is another scripting language that is used very widely in Ubuntu world. In particular, it has os.walk() module which allows us to perform the same action as above - traverse directory tree and obtain list of files that contain desired string.
As one-liner this can be done as so:
$ python -c 'import os;print([os.path.join(r,i) for r,s,f in os.walk(".") for i in f if "postgis-2.0.0" in i])'
['./testdir/texts/postgis-2.0.0']
Full script would look like so:
#!/usr/bin/env python
import os;
for r,s,f in os.walk("."):
    for i in f:
        if "postgis-2.0.0" in i:
            print(os.path.join(r,i))
