Apologies if this is obvious, but I am in a hurry, need answer quickly...
Just installed XFCE, most hardware is good so far
NEED to scan some documents right now, cannot figure out how to do that.
I downloaded driver from Epson (Epson 1660 perfection scanner) that is correct for my 32bit chip and ubuntu.
Don't know what to do now!
Readme file says
Change to the folder where you downloaded this scanner driver bundle,
extract it and install all components with
   tar xaf iscan-bundle-1.0.2.x86.deb.tar.gz
   cd iscan-bundle-1.0.2.x86.deb
   ./install.sh
in a terminal window.
You will be asked for your password to acquire the privileges needed
to install software on your system.  This works the same way as with
your regular software installation procedure.
May be dumb question , but can you step by step me to how "change to the folder"? Or, I guess I am saying what is the correct terminal language to take care of this post haste?
I pasted the whole string, and that did not work, and then I pasted just "./install.sh" which also didn't work.
((I will be learning how to use this OS like a normal person starting tomorrow, but need my scanner today))
mikewhatever
  • 33,013
Here are the steps needed to install using the file you already downloaded.
  1. Double-click iscan-bundle-1.0.2.x86.deb.tar.gz and extract to your home folder (it's the same folder that contains Documents, Music, etc.); you should see there a new folder with the name iscan-bundle-1.0.2.x86.deb
  2. Open the terminal (it opens by default in your home folder) and do cd iscan-bundle-1.0.2.x86.deb, press Enter; you're now at the iscan-bundle-1.0.2.x86.deb folder
  3. Run the installer script with ./install.sh (./ indicates the file install.sh is inside the folder you're already in)
