whilst there are work arounds Permanently Disable Wireless Drivers and Wireless Internet on tablet-PC
, I would like to see the airplane icon in the top bar to prove that wireless is off. (the best way would be to take out the hardware as I never use wifi )
the setting is in settings, wifi , airplane mode.
but this resets to enabled on reboot. I would like it permanently selected there, so it shows in top bar.
ryzen5 22.04.1 gdm3 5.15.0-56-generic
pierrely
  • 725
this worked for me lovely, and the airport icon shows up the top , I only need to run it on startup/reboot.
not mine, got it from here, so upvote there.
Turn Airplane Mode on/off via terminal
#!/bin/bash
radio="$(nmcli radio all | awk 'FNR == 2 {print $2}')"
if [ "$radio" = "enabled" ] then nmcli radio all off else nmcli radio all on fi
if rfkill list bluetooth | grep -q 'yes$' ; then rfkill unblock bluetooth else rfkill block bluetooth fi
also I ran it as sh, which is dash not bin (as I understand it). else I could run it as 'bash xxxx,sh'
pierrely
  • 725
So less about: how make it turn off / how to make the off status remain as such between refresh or reboot
MORE about: relocating the status icon of the setting to a place more prominent.
As with most cel phones where you can rearrange the notification icons and assign them priorities.
You could research and build a macro that turns off the wifi and then add a line to the REBOOT sequence that initiates that macro near the end of rebooting. If you determine a resource for that please be sure to include.
Does the interface, where your icon currently displays, allow you to interact with the icon as a means of interacting with the settings it represents?
rfkill block all
works a treat from 22.04 thinks my desktop should have wifi, so sets airplane on as I do ot use wifi. This means that bluetooth cannot work. Why? comment in first answer. AND it did not require sudo. simplest solution.
pierrely
  • 725
