I have installed Ubuntu Server 22.04.1 LTS on a PC that I intend to use as a media server and compute node. Atop Ubuntu server, I have installed the default gnome desktop. I am able connect to this server using SSH from other machines.
I want to be able to:
Remotely access the whole GUI of the server.
I found this post which seems to be running only apps, not the entire display of the server.
I do not want to use VNC as I will be using this server over the internet.
What is the simplest way to achieve this?
server will need xrdp installed and set up if you do not want to use VNC. a guide is on DigitalOcean including configuring requiring passwords
Remmina client will connect to VNC and RDP so you can test over LAN.
Crighton
  • 492
