I just upgraded my system from Ubuntu 20.04 to 22.04, however, the VLC media player is not working at all, I tried to uninstall it and re-install it (vlc 3.0.18) again using sudo snap install vlc but it's still not launching
I tried the solutions from this thread, but nothing worked. One solution suggested to install from ppa:videolan/master-daily and then sudo apt-get install vlc and it did work, however, the app was unstable. I checked their bug tracking system, no one reported such an issue over there.
pbhj
  • 3,364
6 Answers6
16
Ubuntu 22.04.2 LTS
sudo rm /var/cache/fontconfig/*
rm ~/.cache/fontconfig/*
fc-cache -r
See the original post
12
  1. Have you tried installing VLC from the default repository by just using the following command:
    sudo apt install vlc
  2. You can also try installing VLC using flatpak:
    sudo apt install flatpak
    sudo flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
    flatpak install flathub org.videolan.VLC
You can refer to following guide.
https://linuxgenie.net/how-to-install-vlc-in-ubuntu-22-04/
Faced the same issue.
VLC 3.0.18 installed from Snap is missing this package:
sudo apt install libaribb24-0
Open "Applications", uninstall the snap-VLC, reinstall VLC from "ubuntu-jammy-universe (deb)"
There is a drop-down in the upper right corner which says "snap-store (Snap)" by default
Edit: Check if you have corrupted packages (after upgrade). Me, I had a "broken" libdvd... So you may try to fix this first:
sudo dpkg-reconfigure libdvd-pkg
I ran these commands and they worked for me. I am using Ubuntu 24.04
sudo apt update
sudo apt upgrade
I had the same issue for me I solve it by removing the previously installed version (I installed from App Center) and install it from a default repo
sudp apt update
sudo apt upgrade -y
sodo apt install vlc -y
