I just moved from Windows 10 to Ubuntu 22.10 on my HP Notebook - 15-ay542tu laptop which has
CPU: Intel i3-6006U CPU @ 2.00GHz
RAM: 12GB RAM
400 GB SSD (ubuntu installed here)
1TB storage disk
Problem
The system freezes randomly for a minute or two and comes back online.
  • It used to happen even on windows (but there were so many bloated softwares running, therefore I thought high CPU usage was the problem).
  • The frequency of freezing increased on Ubuntu than on windows (contrary to my expectations). On windows, it used to be 2-3 times in an hour. On Ubuntu it became 8-10 times in an hour while I only just webbrowswer with 7-8 open tabs.
My conclusions so far
  • I think its not high CPU usage or insufficient RAM/Swap: result of top
top - 14:04:25 up  1:08,  1 user,  load average: 5.51, 3.42, 2.96
Tasks: 253 total,   2 running, 251 sleeping,   0 stopped,   0 zombie
%Cpu(s):  5.7 us,  1.9 sy,  0.0 ni, 92.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :  11860.4 total,   7889.6 free,   1455.6 used,   2515.1 buff/cache
MiB Swap:  10240.0 total,  10240.0 free,      0.0 used.   9554.6 avail Mem
PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
1221 hp 20 0 4675648 267916 130600 S 13.7 2.2 3:46.93 gnome-shell
6977 hp 20 0 568824 52152 39284 R 6.2 0.4 0:04.44 gnome-terminal- 7433 hp 20 0 21824 4096 3212 R 1.2 0.0 0:00.97 top 22 root 20 0 0 0 0 S 0.6 0.0 0:05.73 ksoftirqd/1
58 root 0 -20 0 0 0 I 0.6 0.0 0:01.74 kworker/1:1H-events_highpri
92 root 0 -20 0 0 0 D 0.6 0.0 0:05.97 kworker/u9:0+i915_flip
  • I think its not SSD or storage disk
for SSD: enter image description here for storage disk: enter image description here
What is it then? I am clueless. I don't know how to zero-in on the cause of these freezes.
No. of freezes are more on ubuntu than on windows
EDIT: Now that I've been using Ubuntu for 2 days. I noticed that no. of freezes have increased phenomenally on Ubuntu. I have no clue why. System resources are consumed less on Ubuntu but freezes are more when compared to windows.
I don't know if its relevant but at the time of booting i get this message before login screen is shown enter image description here
Also today morning system crashed and showed this error enter image description here
EDIT 2: When I run from live usb there are no freezes
I tried running Ubuntu live from USB (without installing) then there are no freezes. This immediately makes me think that the SSD on which ubuntu was installed is at fault. But I don't see any errors in SMART data.
What could be the issue? Is it the SSD that might be causing these freezes? What should I do now. The disk is still under warranty
claws
  • 121
I think the answer might be in your BIOS. The boot message before login screen is trying to latch onto the TPM information in MSFT0101 to show that you have a legitimate Windows system. It may have been corrupted during its MS Windows lifetime.
You will want to check ACPI settings in your BIOS and try to turn this off.
Also this article tells you how to disable ACPI in your BIOS. https://www.compuhoy.com/how-do-i-turn-off-acpi-mode-in-bios/#How_do_I_change_my_ACPI_settings_in_BIOS
mondotofu
  • 817
