UPDATE: I have re-installed (3 times) Ubuntu, and performed sudo apt policy libc6 libc6-dev with this output:
libc6:
Installed: 2.35-0ubuntu3.1
Candidate: 2.35-0ubuntu3.1
Version table:
*** 2.35-0ubuntu3.1 100
100 /var/lib/dpkg/status
N: Unable to locate package libc6-dev
I then did a sudo apt update and another sudo apt policy libc6 libc6-dev and got this output:
libc6:
Version table:
*** 2.35-0ubuntu3.1 500
500 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
2.35-0ubuntu3 500
500 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
libc6-dev:
Installed: (none)
Version table:
2.35-0ubuntu3.1 500
2.35-0ubuntu3 500
I then was able to perform sudo apt-get install build-essential gdb g++ successfully.
Thank you @steeldriver for looking into this issue with me. I don't know how to close this Question; I suppose the Moderators will eventually do that. Cheers!!
I am running into the same problems as stated in an older question (July 2018), but now (Dec 2022) with a newer version of Ubuntu (22.04 LTS).
When installing the g++ compiler and gdb debugger using sudo apt-get install build-essential gdb g++ I get the following output, with an error for libc6-dev :
Reading package lists... Done
Building dependency tree... Done
gdb is already the newest version (12.0.90-0ubuntu1).
gdb set to manually installed.
libc6-dev : Depends: libc6 (= 2.35-0ubuntu3) but 2.35-0ubuntu3.1 is to be installed
This is the output of cat /etc/os-release
PRETTY_NAME="Ubuntu 22.04.1 LTS" NAME="Ubuntu" VERSION_ID="22.04"
VERSION="22.04.1 LTS (Jammy Jellyfish)" VERSION_CODENAME=jammy
ID=ubuntu ID_LIKE=debian HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=jammy
The last comment offered by user Olimjon in that question recommends a clean installation of Ubuntu, which I have done twice, but the problem persists.
Ultimately, my goal is to follow the tutorial on OpenGL by Victor Gordan, however, I am not able to compile and run the examples successfully.
Any suggestions on how to repair the libc6-dev dependencies?
Additional & Updated Information:
Output of apt policy libc6 libc6-dev is
libc6:
Version table:
2.35-0ubuntu3 500
libc6-dev:
Installed: (none)
Version table:
2.35-0ubuntu3 500
The sources.list file contains:
# deb cdrom:[Ubuntu 22.04.1 LTS _Jammy Jellyfish_ - Release amd64 (20220809.1)]/ jammy main restricted
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
deb http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
Major bug fix updates produced after the final release of the
distribution.
deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb http://us.archive.ubuntu.com/ubuntu/ jammy universe
deb-src http://us.archive.ubuntu.com/ubuntu/ jammy universe
deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu jammy-security main restricted
deb-src http://security.ubuntu.com/ubuntu jammy-security main restricted
deb http://security.ubuntu.com/ubuntu jammy-security universe
deb-src http://security.ubuntu.com/ubuntu jammy-security universe
deb http://security.ubuntu.com/ubuntu jammy-security multiverse
deb-src http://security.ubuntu.com/ubuntu jammy-security multiverse
This system was installed using small removable media
(e.g. netinst, live or single CD). The matching "deb cdrom"
entries were disabled at the end of the installation process.
For information about how to configure apt package sources,
see the sources.list(5) manual.
