I installed the latest snap Okular 22.08.2 on Ubuntu 20.04 (x11, gnome). I encountered two problems:
  1. I am tying to open a .pdf attachment from thunderbird with Okular (snap). Following this guide, I created a tmp folder in my home (location accessible by Okular) and mounted the /tmp folder there: mkdir /home/you/tmp sudo mount --bind /tmp /home/you/tmp/. When double-clicking on the attachment, a read-only file is correctly created in /tmp/pid-xxxxx/attachment.pdf, Okular the default application opens, but I get an error message: Could not open file:///tmp/pid-xxxxx/attachment.pdf. Nevertheless, going to the folder /tmp/pid-xxxxx/, I am able to open the created file by simply double-clicking on it. Is it a snap connections problem?
  2. Although I set the "open in tabs" option and restarted the app, upon clicking on .pdf files, they will be opened into different instances instead of in tabs. EDIT: I have just noticed that if a pdf is opened via right click -> open with another application -> Okular, instead of simply double-clicking, the file is actually opened in a tab of the already opened Okular. How is it possible to code this as default behaviour?
I would appreciate any help. Thank you!
EDIT: requested connections output.
$ snap connections okular
Interface                                          Plug                                         Slot        Notes
audio-playback                                     okular:audio-playback                        :audio-playback        -
content[icon-themes]                               okular:icon-themes                           gtk-common-themes:icon-themes                                                   -
content[kde-frameworks-5-98-qt-5-15-6-core20-all]  okular:kde-frameworks-5-98-qt-5-15-6-core20  kde-frameworks-5-98-qt-5-15-6-core20:kde-frameworks-5-98-qt-5-15-6-core20-slot  -
content[sound-themes]                              okular:sound-themes                          gtk-common-themes:sound-themes                                                  -
cups-control                                       okular:cups-control                          -        -
dbus                                               -                                            okular:session-dbus-interface                                                   -
desktop                                            okular:desktop                               :desktop        -
desktop-legacy                                     okular:desktop-legacy                        :desktop-legacy        -
home                                               okular:home                                  :home        -
network                                            okular:network                               :network        -
network-bind                                       okular:network-bind                          :network-bind        -
opengl                                             okular:opengl                                :opengl        -
removable-media                                    okular:removable-media                       :removable-media        -
wayland                                            okular:wayland                               :wayland        -
x11                                                okular:x11                                   :x11
giammi56
  • 140
