I am on Ubuntu 22.10 and I cannot change SSH default port. I have tried the following:
Edited
/etc/ssh/sshd_config, left the default#Port 22line but addedPort 1234below it.Then added allow rule for it in UFW using the command:
sudo ufw allow 1234which added:
To Action From 1234 ALLOW Anywhere 1234 (v6) ALLOW Anywhere (v6)
I then restarted the SSH service using 2 different methods (see start of block below), but I saw no change. Service status states it started listening on port 22 and to verify this I checked the listening ports and sure enough it's still 22.
$ sudo systemctl restart ssh
$ sudo service ssh restart
$ systemctl status ssh
ssh.service - OpenBSD Secure Shell server
Loaded: loaded (/lib/systemd/system/ssh.service; disabled; preset: enabled)
Drop-In: /etc/systemd/system/ssh.service.d
└─00-socket.conf
Active: active (running) since Mon 2022-11-07 10:12:52 AEDT; 5s ago
TriggeredBy: ● ssh.socket
Docs: man:sshd(8)
man:sshd_config(5)
Process: 54858 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=0/SUCCESS)
Main PID: 54859 (sshd)
Tasks: 1 (limit: 1020)
Memory: 1.3M
CPU: 13ms
CGroup: /system.slice/ssh.service
└─54859 "sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups"
Nov 07 10:12:52 webserver.abc.com systemd[1]: Starting OpenBSD Secure Shell server...
Nov 07 10:12:52 webserver.abc.com sshd[54859]: Server listening on :: port 22.
Nov 07 10:12:52 webserver.abc.com systemd[1]: Started OpenBSD Secure Shell server.
ss -tlpn
State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0 4096 :22 :* -
Am I missing a step or doing something wrong? I do note the service status has preset: enabled, but multiple guides I've read haven't mentioned anything about disabling anything like presets.
EDIT:
Thanks matigo for reminding me, but sshd.service doesn't seem to be installed yet. I have the config files and can remote in just fine, not sure if I just don't understand and I need to install sshd for it to take over the default SSH operations?
