I have used this MSI katana computer for 2 months with no issue. Installed WINE and installed NVIDIA Drivers to be able to use Steam, which was installed but I hadn't run yet. The computer started freezing randomly. No pattern to when it freezes.(Log in, desktop, in Chrome, in Steam, with just terminal open, etc)
SysRq + REISUB doesn't work, Alt+F2 doesn't open dialog, CTRL+ALT+F3 doesn't open TTY, so a hard shutdown is necessary.
Uninstalled Ubuntu 22 LTS Installed Ubuntu 20 LTS and had the same problem. Uninstalled Ubuntu 20 and reinstalled Ubuntu 22.
Did the updates during and after reinstall via terminal. Restarted the computer and checked the logs. There were errors with nouveau on boot. Installed NVIDIA recommended driver. Downloaded and opened Steam, with one Chrome tab running. Computer froze.
The hardware logs after last hard shutdown:
15:06:27 kernel: iwlwifi 0000:00:14.3: iwl_trans_reclaim bad state = 0
15:06:27 kernel: nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
15:06:23 kernel: ieee80211 phy0: Hardware restart was requested
15:06:23 kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
15:06:23 kernel: iwlwifi 0000:00:14.3: Fseq Registers:
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00005B02 | IML/ROM data1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state
15:06:23 kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000004 | isr status reg
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00B5010D | last host cmd
15:06:23 kernel: iwlwifi 0000:00:14.3: 0xC0887F3C | stack pointer
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x051EBD73 | frame pointer
15:06:23 kernel: iwlwifi 0000:00:14.3: 0xF1C864E0 | umac minor
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000042 | umac major
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3
15:06:23 kernel: iwlwifi 0000:00:14.3: 0xC0080964 | umac data2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x01000000 | umac data1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0xC0080964 | umac interruptlink2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x8047430E | umac interruptlink1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x80455AE6 | umac branchlink2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
15:06:23 kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
15:06:23 kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00009090 | flow_handler
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x000000E7 | l2p_addr_match
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00018034 | l2p_duration
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00004A88 | l2p_control
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00012C82 | wait_event
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x9C6B009D | last cmd Id
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00C3428C | isr3
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x08F0000A | isr2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x20028000 | isr0
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x80C8FC04 | hcmd
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00C89004 | board version
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000351 | hw version
15:06:23 kernel: iwlwifi 0000:00:14.3: 0xF1C864E0 | uCode version minor
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000042 | uCode version major
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x051EBD75 | time gp2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x0000002A | tsf hi
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x4B0560B4 | tsf low
15:06:23 kernel: iwlwifi 0000:00:14.3: 0xC7C15F52 | beacon time
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x01000000 | data2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00012C82 | data1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x004C183E | interruptlink2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x004C183E | interruptlink1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x004CB01A | branchlink2
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x0000A200 | trm_hw_status0
15:06:23 kernel: iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
15:06:23 kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
15:06:23 kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
15:06:23 kernel: iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x1.
15:06:23 kernel: iwlwifi 0000:00:14.3: Queue 5 is stuck 67 36
15:06:06 kernel: nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
15:05:50 kernel: nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
15:05:29 kernel: nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
15:05:28 kernel: nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
15:05:27 kernel: nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
15:05:27 kernel: nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
15:05:10 kernel: logitech-hidpp-device 0003:046D:400A.0005: HID++ 2.0 device connected.
15:05:03 kernel: nouveau 0000:01:00.0: mc: intr 00000040
(lines 107 - 1986 repeats : 15:05:03 kernel: nouveau 0000:01:00.0: mc: intr 00000040)
15:04:56 kernel: r8169 0000:03:00.0 enp3s0: Link is Down
15:04:56 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
15:04:56 kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
15:04:56 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
15:04:56 kernel: Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
15:04:56 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
15:04:56 kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
15:04:55 kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
15:04:55 kernel: nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
15:04:55 kernel: snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
15:04:55 kernel: iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
15:04:55 kernel: nouveau 0000:01:00.0: bios: version 94.07.32.00.23
Open to any suggestions for how to fix the freezing / avoid hard shutdown.
