Is there a command to detect the type of processor, type of graphics card, type of hard drive, just the basic hardware my computer is running?
I'm running 12.04.
I'm running 12.04.
You can easily find this most of this information out with the dmidecode command:
sudo dmidecode -q
It may be a little verbose though. To find out information about a specific device, you can use the -t type argument. More information on that is here, http://www.thegeekstuff.com/2008/11/how-to-get-hardware-information-on-linux-using-dmidecode-command/
Another option would be to use lshw
sudo lshw
To find out the disk usage of your hard drive, you can use the df command:
sudo df -h
This command will tell you about your hardware (including the specific components you've listed):
sudo lshw
It's possible to run lshw without sudo (i.e., not as root) but it may not give as complete or accurate information.
You can run lshw with the -C flag and an argument, to get information about a specific class of hardware. See man lshw for details.
You can use also lspci, possibly filtering its output with grep (look for VGA or video keywords for GPU information), for example try:
$ lspci -v | grep VGA
See man lspci and also http://www.cyberciti.biz/faq/linux-tell-which-graphics-vga-card-installed/
"dmidecode" is a handy native linux command which gives many hardware details. I've written a script to get all the details and if someone is interested can check out here:
Thanks, Mssm
The hw-probe tool collects outputs of most popular hardware listers (hwinfo, dmidecode, lspci, etc.): https://hub.docker.com/r/linuxhw/hw-probe/
Probe example: https://linux-hardware.org/?probe=0b29192f95
I'm the author of this project, feel free to ask any questions in comments!
