How can I check the technical info on my notebook with Ubuntu 14.04?
I would like to check the dimension and if is IDLE or SATA
Ale
  • 241
The utility hdparm is IMHO the best tool for this job. Simply run as follows:
sudo hdparm -I /dev/sda
and you will have more than enough information on your HDD. There are many options available (see in the reference at the base of this post), I have given:
-I   Detailed/current information directly from drive
hdparm is part of a default installation on Trusty Tahr so no extra installation required...
References:
andrew.46
  • 39,359
