14
I've created a user and made his home directory /var/www/mysite/ftpdir
I've also added a Match user entry for this user in sshd_config with a ChrootDirectory that points to /var/www/mysite
I've restarted ssh to pick this up.
When I log in with sftp - the user still goes to the user's old directory ie /home/user
What am I missing?
hawkeye
  • 4,107
This is the process:
  1. Add the user to the group: sudo usermod -aG www blub as in Whats the simplest way to edit and add files to "/var/www"?
    or just use sudo adduser <username> www-data
  2. Install vsftpd sudo apt-get install vsftpd
  3. Configure vsftpd for remote access: sudo nano /etc/vsftpd.conf and inside the file set
    chroot_local_user=YES
    and ensure this is commented out:
    #chroot_list_enable=YES
    as per documentation.
  4. Restart nsftp: sudo service vsftpd restart
  5. Configure the user's home directory to the web directory (not in /home):
    sudo usermod -d /var/www/mysite/ftpaccessdir <username>
  6. Configure ssh chroot
    sudo nano /etc/ssh/sshd_config
    add the following to the end:
    Subsystem  sftp  internal-sftp
    Match user <username>
        ChrootDirectory /var/www/site
        ForceCommand internal-sftp
    AllowTcpForwarding no
    and ensure that further up in the file that this is commented out (ie before the one you just added)
    #Subsystem sftp /usr/lib/openssh/sftp-server
  7. Restart ssh
    sudo service ssh restart
  8. Change the permissions for apache:
    chown root:root /var/www
    chown root:root /var/www/site
    chmod 755 /var/www
    As in the docs here.
  9. Ensure that your directory has www-data access
    sudo chown -R www-data:www-data /var/www/site
    chmod 755 /var/www/site
hawkeye
  • 4,107
I've a simple method and that worked for me for apache.
sudo useradd -d /var/www demo_user -g www-data
sudo passwd demo_user
That's it in case you still face permission issue use chmod and chown to address them according to your needs.
If you are getting connection refused error at end then make sure that "Subsystem sftp internal-sftp" is place after "UsePAM yes". If not then update and Restart ssh and it worked.
