It's honestly a great question, as I realized when I went through the various scenarios below. The way that WSL works here is, I have to agree, confusing. There are a number of "issues" that come up related to this on the WSL Github repo, but the reality is that this behavior is "by design".
From the WSL/Systemd announcement:
It is also important to note that with these change, systemd services will NOT keep your WSL instance alive. Your WSL instance will stay alive in the same way it did before, which you can (read more about here](https://devblogs.microsoft.com/commandline/background-task-support-in-wsl/).
In other words, WSL is designed to terminate Ubuntu in certain situations, but the linked post isn't very clear about exactly what those scenarios are. To understand them (and how WSL behaves) a bit better, let's start out with the (at least) four different ways you can start a background task or service (a.k.a. daemon) on Ubuntu on WSL:
Interactively, from the command line via the command itself or using the service helper. E.g.:
sudo service cron start
# or even
sudo /usr/sbin/cron
This, of course, will work on any version of WSL, but the SysVInit service may only work for certain distributions (such as Ubuntu) and services.
(Important) note that commands run inside your shell startup scripts are considered "interactive" for this purpose. That will come in handy in my ultimate (hacky) solution.
Interactively, as a background task from the shell. E.g.:
nohup sleep 100000 &
Under Windows 11, you can start a daemon automatically at WSL startup via /etc/wsl.conf. E.g.:
[boot]
command = service cron start
And starting with WSL 0.67.6, using Systemd. This can happen either interactively (sudo systemctl cron start), automatically via /etc/systemd links, or as a dependency of another service. E.g.
Note that the Snap daemon (snapd) starts automatically via Systemd once enabled in WSL.
With those scenarios in mind, we need to look at when WSL will terminate Ubuntu. As I said, it's "confusing". I wish I could come up with a summary statement to describe the behavior, but I struggle with it. The best I can do is provide examples:
Summary
- Will not terminate
- Will terminate
- Will terminate
Details and examples
A service started interactively via the commandline will prevent WSL from terminating Ubuntu. We can demonstrate this by:
- Temporarily disabling Systemd in
/etc/wsl.conf
- Exiting Ubuntu
- Start PowerShell
wsl --shutdown
- Restart Ubuntu via
wsl ~ (if needed, wsl ~ -d Ubuntu-22.04, etc.)
- Exit the shell
- Wait a minute (25 seconds, by default, should be sufficient) and check
wsl -l -v to show that Ubuntu is still in the Running state.
wsl -e ps axjff should show that cron is still running, even though no shell is running.
A background task started interactively via the commandline will also prevent WSL from terminating Ubuntu. Following the previous example:
- With Systemd still disabled, from PowerShell,
wsl --shutdown
- Start Ubuntu (e.g.
wsl ~)
- Run
- Hit Enter one extra time to dismiss the
nohup message
- Exit the shell/Ubuntu back to PowerShell.
- Wait 30 seconds to a minute and
wsl -l -v to show that Ubuntu is still running.
wsl -e ps axjff should show that the sleep command is still running, even though no shell is running.
A service/process started via /etc/wsl.conf, on the other hand, will not prevent WSL from terminating Ubuntu.
Starting with the previous example (Systemd disabled)
In Ubuntu, sudo -e /etc/wsl.conf and add the following:
[boot]
Exit Ubuntu, and from PowerShell, wsl --shutdown
Restart Ubuntu via wsl ~
ps axjff to show that cron is running as a subprocess of one of the /init parents.
After 30 seconds to a minute wsl -l -v will show that Ubuntu is no longer running. It has been terminated.
A service/process started via Systemd will also not prevent WSL from terminating Ubuntu. Demonstration (although you are experiencing this):
Edit /etc/wsl.conf and re-enable Systemd while disabling (commenting out or removing) the command.
Exit Ubuntu
In PowerShell, wsl --shutdown
wsl ~ to start Ubuntu.
ps axjff will show the Systemd services running and/or starting up.
After a minute:
sudo systemctl stop cron
sudo systemctl start cron
This has the effect, obviously, of simply stopping cron then restarting it. The point here is to show that even though we explicitly started cron interactively, this will not prevent WSL from terminating Ubuntu.
After 30 seconds to a minute, wsl -l -v will show that Ubuntu has been Stopped.
As for your particular question, since lxd is simply a Snap, which is running in a containerized environment started by Systemd, it is getting terminated as well. Well, bummer ...
Solution
Hopefully there's a more permanent fix incoming, as one of the WSL developers did indicate a desire to keep distros running.
In the meantime, a solution (and there may, of course, be more) is to start a long-running process via your shell startup-files. In my case, I typically run keychain.
There are a few things about Keychain that allow it to work nicely in this case:
- It's available in the default Ubuntu repositories
- It already starts a singleton instance of
ssh-agent. In other words, if ssh-agent is already running, it will attach to it rather than starting a new one.
- It can run quietly, and without interaction if no keys are added
To set this up:
sudo apt update && sudo apt install keychain -y
sudo -e /etc/profile.d/keep_wsl_running.sh
And add the following:
#!/usr/bin/env sh
eval $(keychain -q)
This script:
Runs when you start your shell (assuming most shells such as Bash and Zsh). Note that it will not run if you use Fish as your shell. If you (or any future reader) does want to use Fish (or another shell that doesn't process /etc/profile.d), ask a separate question on how to handle this scenario. I do have a solution, but this answer is (as usual) long enough already ;-).
Evaluates the output of keychain, so that it finds any existing ssh-agent (or starts a new one, if not) and sets the environment variables for the shell to point to it.
-q, as you probably imagine, simply runs keychain quietly, without output
Having a the ssh-agent running (that was started via /etc/profile.d) will prevent WSL from terminating the Ubuntu distribution/instance/container. Ubuntu will continue running after you close the terminal window, and your lxd (and other daemons/services installed by Snap) will stay up as well.
To allow Ubuntu to terminate gracefully, just get rid of the ssh-agent. This can be done several ways, including:
keychain -k all
Of course, make sure that any other services that you started interactively are also gone. Once that condition is met, WSL will gracefully terminate Systemd and its units/services.
There's one corner case here, and that's if you start a wsl -u root session. In that case, ssh-agent will also be running as root, and you'll need to sudo keychain -k all.
