I want to mount a raw made with New-VHD -Path "H:\comfyui\ComfyUI.vhdx" -SizeBytes 1000GB -Dynamic vhdx disk into WSL2 (ubuntu-22.04), i tried:
how to mount .vhdx image in lubuntu
(example 2 raised that error too.)
but i got this error:
/mnt/h/comfyui$ sudo guestmount --add ComfyUI.vhdx -i --rw /mnt/ComfyUI
libguestfs: error: /usr/bin/supermin exited with error status 1.
To see full error messages you may need to enable debugging.
Do:
export LIBGUESTFS_DEBUG=1 LIBGUESTFS_TRACE=1
and run the command again. For further information, read:
http://libguestfs.org/guestfs-faq.1.html#debugging-libguestfs
You can also run 'libguestfs-test-tool' and post the *complete* output
into a bug report or message to the libguestfs mailing list.
So that didn't work. I also tried just mounting it with: wsl --mount "H:\comfyui\ComfyUI.vhdx" --type ext4 and that didn't work either.
I also do not know how to format to ext4 from windows, so I don't know what I though it would work. and -type raw doesn't work either.
I also ask chatgpt for help and after some different iteration of the wsl --mount
I am not sure if it matter but i have a docker desktop and that can mount it's stuff:
Docker off:
sda 8:0 0 388.4M 1 disk
sdb 8:16 0 8G 0 disk [SWAP]
sdc 8:32 0 1T 0 disk /mnt/wslg/distro
Docker on:
loop0 7:0 0 531.9M 1 loop /mnt/wsl/docker-desktop/cli-tools
loop1 7:1 0 625M 1 loop
sdd 8:48 0 1T 0 disk /mnt/wsl/docker-desktop/docker-desktop-user-distro
sde 8:64 0 1T 0 disk
If I need to add any log please tell me so! Thanks in advance!
