Installing mainline kernels is not an option because it is not signed for SecureBoot: I hit bad shim signature and I cannot disable SecureBoot nor enroll my own signing keys on my system (locked BIOS).
How can I install the latest signed available kernel, at this time kinetic/linux-generic ie around 5.19.0-19, made for 22.10, on 22.04 LTS?
Note that such kernels only end up in ubuntu LTS only ~4 months later (source).
What i have tried so far:
root=http://fr.archive.ubuntu.com/ubuntu/pool/main/
wget \
$root/l/linux-signed/linux-image-5.19.0-19-generic_5.19.0-19.19_amd64.deb \
$root/l/linux/linux-headers-5.19.0-19-generic_5.19.0-19.19_amd64.deb \
$root/l/linux/linux-headers-5.19.0-19_5.19.0-19.19_all.deb \
$root/l/linux/linux-modules-5.19.0-19-generic_5.19.0-19.19_amd64.deb \
$root/l/linux/linux-modules-extra-5.19.0-19-generic_5.19.0-19.19_amd64.deb \
$root/l/linux/linux-modules-iwlwifi-5.19.0-19-generic_5.19.0-19.19_amd64.deb
sudo dpkg -i *.deb
kernel does seem to pass the shim signature check, but locks up, 100% CPU, and only prints the unhelpful "standard" buggy DELL bios errors:
DPC: RP PIO log size 0 is invalid
ACPI error: Thread ... cannot release mutex [ECMX] ...
Aborting method _SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER)
eddygeek
  • 1,839
It seems either I initially hit an issue with specific version 5.19.0-19, or latest firmware&microcode was needed.
So, the following instructions work:
major=5.19.0
patch=24
rev=25
wget
$root/l/linux-signed/linux-image-$major-${patch}-generic_$major-${patch}.${rev}amd64.deb
$root/l/linux/linux-headers-$major-${patch}-generic
$major-${patch}.${rev}all.deb
$root/l/linux/linux-modules-$major-${patch}-generic
$root/l/linux/linux-modules-extra-$major-${patch}-generic
$root/l/linux/linux-modules-iwlwifi-$major-${patch}-generic
$major-${patch}.${rev}_amd64.deb
sudo dpkg -i *.deb
fixes "Possible missing firmware /lib/firmware/i915/skl_guc_70.1.1.bin for module i915" etc
wget
$root/a/amd64-microcode/amd64-microcode_3.20220411.1ubuntu3_amd64.deb
$root/l/linux-firmware/linux-firmware_20220923.gitf09bebf3-0ubuntu1_all.deb sudo dpkg -i --auto-deconfigure linux-firmware_.deb amd64-microcode_.deb
To uninstall
major=5.19.0
patch=19
sudo apt remove linux-image-$major-${patch}-generic linux-headers-$major-${patch}-generic linux-headers-$major-${patch} linux-modules-$major-${patch}-generic linux-modules-extra-$major-${patch}-generic linux-modules-iwlwifi-$major-${patch}-generic
Note: you will need to edit the major/patch/rev and firmware/microcode version according to what can be found in http://fr.archive.ubuntu.com/ubuntu/pool/main/ - as only the latest build is present.
Note2: Ubuntu 24.04 kernel headers cannot be used in 22.04 due to:
Depends: libc6 (>= 2.38) but 2.35-0ubuntu3.7 is to be installed
Depends: libelf1t64 (>= 0.144) but it is not installable
Depends: libssl3t64 (>= 3.0.0) but it is not installable
eddygeek
  • 1,839
