Research
Before marked as dupe, I have done my research. I've tried the suggestion as well to add $USER to docker group, and log out, log in, even restart, execute newgrp docker all that is done here
I just did what is written here in the docs to install Docker Desktop via the deb package, including the pre-requsite set-up repository here, plus the post-install step which mentioned adding user to docker group. Note I didn't install the Docker Engine, because I thought its not necessary for Docker Desktop, this is correct right?
It seems like I have entirely different problem
Result
After installation I just simply run this systemctl --user start docker-desktop which opens up the DD (Docker Desktop) and it just says "docker desktop starting .. "
Here's some maybe related result throughout my research:
  1. sudo docker run hello-world
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
  1. docker run hello-world
docker: Cannot connect to the Docker daemon at unix:///home/name/.docker/desktop/docker.sock. Is the docker daemon running?.
See 'docker run --help'.
  1. ls -la /var/run/docker.sock
srw-rw---- 1 root docker 0  9月 26 22:53 /var/run/docker.sock
  1. docker version
Error response from daemon: dial unix docker.raw.sock: connect: no such file or directory
Client: Docker Engine - Community
 Cloud integration: v1.0.29
 Version:           20.10.18
 API version:       1.41
 Go version:        go1.18.6
 Git commit:        b40c2f6
 Built:             Thu Sep  8 23:11:43 2022
 OS/Arch:           linux/amd64
 Context:           desktop-linux
 Experimental:      true
  1. service docker status or sudo systemctl restart docker
Unit docker.service could not be found.
Number 5 is really weird, something I don't find in other posts. How to fix the "Unit docker.service could not be found." error?, here just mention about installing from snap, but not my case.
Any help is greatly appreciated, I've been stuck for ~6 hours try debugging this
ordem
  • 35
Also encountered this problem recently. Just copy&paste the official instructions here in case the website changes and someone needs that specific solution.
The kvm module should load automatically if the host has virtualization support. To load the module manually, run:
$ modprobe kvm
Depending on the processor of the host machine, the corresponding module must be loaded:
$ modprobe kvm_intel # Intel processors
$ modprobe kvm_amd # AMD processors
If the above commands fail, you can view the diagnostics by running:
$ kvm-ok
To check if the KVM modules are enabled, run:
$ lsmod | grep kvm
kvm_amd               167936  0
ccp                   126976  1 kvm_amd
kvm                  1089536  1 kvm_amd
irqbypass              16384  1 kvm
Set up KVM device user permissions
To check ownership of /dev/kvm, run :
$ ls -al /dev/kvm
Add your user to the kvm group in order to access the kvm device:
$ sudo usermod -aG kvm $USER
Sign out and sign back in so that your group membership is re-evaluated.
